Suspension R56 lowered - more positive rear camber
SuspensionSprings, struts, coilovers, sway-bars, camber plates, and all other modifications to suspension components for Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs.
I just had my 09 JCW coupe lowered
I want to get rid of some of the negative rear camber.
Does anyone know how much camber can I correct without changing
lower control arms?
Right now the rear camber is negative 2 degrees
lower control arms?
I agree just leave it alone. I just had the JCW suspension installed on my 09 factory JCW. This introduced and additional 1 degree of negative camber. It looks a bit odd but does improve the handling.
We just put H&R springs on the sons R56. It dropped it about 1.5 inches and added some additional camber. We had Ireland engineering fixed camber plates which gave us about -1.3 camber. The H&R's bumper that to -1.8 front and -1.3 rear. HE does a lot of highway driving back and forth to school in Charlotte so we'll keep an eye on that, but that'll offset things in autocrosses. Can't wait to do something with the Clubman!
I just had mine lowered, with Eibach Pro-Kit Sport Springs....Hotchkis rear camber kit....the increased negative camber has certainly improved handling - quite considerably! I am very happy with this setup.
lower control arms?...
The amount of adjustment remaining depends on where the bolt is positioned currently. There is .5 degrees of effective adjustment available from a 180 turn of the bolt. If the arm is already shortened, no adjustment will be available.
