Suspension H&R wheel spacers?
Old 04-07-2009 | 04:23 PM
KrautHammer's Avatar
KrautHammer
H&R wheel spacers?
H&R wheel spacers listed in the Moss catalog.
Wondering if anybody has fittem them and what they experienced.
Old 04-07-2009 | 05:08 PM
brianplee's Avatar
brianplee
I put the 15mm spacers on my 2009 JCW and they work just fine. No rubbing and I like the way it looks.
Old 04-07-2009 | 05:12 PM
navicaph's Avatar
navicaph
Any pics? Always wanted to see a Mini with with 15mm spacers.
Old 04-07-2009 | 11:28 PM
MiniBAH's Avatar
MiniBAH
Here is mine, lowered with M7 coilovers and 15mm H&R spacers:
Old 04-08-2009 | 05:37 AM
KrautHammer
Very nice MiniBAH. How about rubbing and scrub radius?
Old 04-08-2009 | 07:48 AM
MiniBAH's Avatar
MiniBAH
No issues whatsoever with rubbing even though my rims are 18s with wider tires (215/40/18), but make sure to get the longer bolts that come with the spacers.
Old 04-08-2009 | 01:21 PM
dtsoccer6's Avatar
dtsoccer6
what tires are those on your mini minibah? Very aggressive!
Old 04-08-2009 | 02:48 PM
KrautHammer
Look like the BFGoodrich g-Force T/A KDW 2.
Old 04-08-2009 | 08:55 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
the real question is what offset of wheel are you using in combo with the spacers????
Old 04-08-2009 | 09:05 PM
ED955S's Avatar
ED955S
Very high quality. TUV approved. Used it in my BMW 330 @ 10mm.
Old 04-08-2009 | 09:13 PM
jcap287's Avatar
jcap287
School away from MINI
What's the difference in driving?
Old 04-08-2009 | 09:20 PM
ED955S's Avatar
ED955S
In my case, nothing. I don't know in the case of Mini.
Old 04-08-2009 | 10:39 PM
Porthos's Avatar
Porthos
Aren't you worried about wearing out your wheel bearings with the spacers
Old 04-08-2009 | 10:44 PM
dtsoccer6's Avatar
dtsoccer6
yeah 10 to 15mm seems like a lot, no?
Old 04-08-2009 | 10:47 PM
dtsoccer6's Avatar
dtsoccer6
Thanks, much appreciated!
Old 04-09-2009 | 01:21 AM
MiniBAH's Avatar
MiniBAH
Correctomondo
Old 04-09-2009 | 06:14 AM
KrautHammer
Many issues with changing the offset of wheels -which is what the spacers do- and the change in scrub radius is the one that concerns me the most since it has a significant effect on handling and steering.
The Minis come with a variety of OEM wheel and tire options and one can chart the parameters of acceptable wheel offsets -OEM are from 45 mm to 52 mm- and decide on spacers and their size.
When calculating scrub radius consider that it is dependent on overall tire diameter.
I am keeping my OEM wheels -until I find a <13 lb 16" wheel- but I am going to taller tires -205/55X16- and so I will be installing a 5 mm spacer to maintain my OEM scrub radius.
Now I have to find 5 mm longer bolts in black.....
Old 04-09-2009 | 08:07 AM
dtsoccer6's Avatar
dtsoccer6
Interesting info here, thanks Hammer!
I just bought OZ Alleggerita 17inch wheels at 13.8 lbs. I'm sure the 16s are much lighter if your looking for a light weight wheel, just an fyi! The wheels I got are at a 38mm offset, should I get 5mm spacers too?
Old 04-09-2009 | 08:09 AM
dtsoccer6's Avatar
dtsoccer6
Originally Posted by MiniBAH
Correctomondo
How well do those babies handle in the twistys?
Old 04-09-2009 | 08:23 AM
MiniBAH's Avatar
MiniBAH
I would say pretty decent, but not as good as the Michelin PS2s on my M Coupe... The grip on the PS2s is ridiculous!
Old 04-09-2009 | 08:25 AM
dtsoccer6's Avatar
dtsoccer6
Really, hmmmmm I'll have to check it out. Thanks for the info MiniBah.
Old 04-09-2009 | 11:01 AM
KrautHammer
No Alleggeritas in 16". The lightest 7X16" at the Tire Bandits is the Enkei RPF1 at 13.7 lbs.
As far as your wheels the offset is listed at 37 mm -and the weight at 14.2 lbs- so they have a back space of 138 mm versus the 143 mm on a stock 6.5X16. If your tires are the same diameter as the OE tires you are good since you get 5 mm more backspace to compensate for 1/2 of the extra 12.7 mm of added wheel width = 6.35 mm. You are within 1.35 mm which is good.
Some people make light of this whole thing and some do not. Long diatribe saved.
Old 04-09-2009 | 12:24 PM
quikmni's Avatar
quikmni
With 17" and 38mm offset wheels, you probably will not have much extra room in the rear. It depends on your tire width and how much your car is lowered. On my 2003 MCS I had 17x7-38 offset with 215/40-17 tires, lowered with H&R springs, and had slight rubbing in the rear. You should not have any problem adding 5mm spacers on the front.
Old 04-09-2009 | 03:16 PM
dtsoccer6's Avatar
dtsoccer6
Sorry bout that, I thought they had a smaller size!
Thanks for the info guys, huge help! I am lowering my car soon, only 1.18 inches all the way around and im going to be running 215/45/17, I think I should be fine.
Old 04-10-2009 | 09:33 AM
ghosthound's Avatar
ghosthound
mmm... i love that beefy look.
Quick Reply: Suspension H&R wheel spacers?
