Suspension NM Motorsport springs it is...
Old 07-18-2009 | 03:54 AM
grodenglaive's Avatar
grodenglaive
Originally Posted by rasputinj
There is no way it dropped an inch in the front looks like more like, 1/2 an inch. Plus I a still getting rubbing in the front passenger side. The ride is good, I just do not like the look of the front being too high in my opinion. It is just a question of NM, Eibach springs or going with H&R coilovers.
Originally Posted by etalj
Really? Sounds bizarre, their website advertises 1" front drop and 3/4" rear drop.
And rubbing with a 1/2" drop, doesn't sound right...(no offense).
The NM drop is 1.2", that's not really a slight drop?
Unless he was shipped the wrong springs - the ones for the R53 drop the rear more than the front.
  #52
Old 07-21-2009 | 12:35 AM
rasputinj's Avatar
rasputinj
I am wondering if I had more drop in the rear because I used R56 TSW springs on a R55?
Does not matter anymore now that the NM springs are on, the ride is better. I will pay attention to see if anything changes as the springs settle in. The drop looks very nice on the R55. So far very happy, thanks for Danny at MiniCorsa squeezing me in and installing them so fast.
  #53
Old 07-21-2009 | 04:04 AM
etalj's Avatar
etalj
before and after pics?
  #54
Old 07-26-2009 | 10:32 PM
rasputinj's Avatar
rasputinj
Here are some pics of what the Clubman looks like after the swap out to NM springs, I will look for some before pics.
So far I love the NM springs
  #55
Old 07-27-2009 | 03:50 AM
Shoof's Avatar
Shoof
Looks great, rasputin!
How's the clearance in the front bumper to the ground?
Which RSB do you have (brand)? What setting did you put the sway bar in (which hole did you mount it through)
You have my setup, just curious as to what I should expect...I have the RSB sitting on the floor in my office now, just waiting for the springs to come in (finally ordered them last week)!
  #56
Old 07-27-2009 | 06:10 AM
JohnJohn's Avatar
JohnJohn
Before and Afters
Before:
After:
  #57
Old 07-27-2009 | 06:22 PM
Powashiftin's Avatar
Powashiftin
Are you guys just changing out the springs? Not shocks?
  #58
Old 07-27-2009 | 06:58 PM
JohnJohn's Avatar
JohnJohn
Yup just springs in my case. I did a rear 25mm sway bar the weekend before. Looking back, I should have ordered them for delivery the same week. Install those two mods together.
  #59
Old 07-27-2009 | 08:47 PM
Shoof's Avatar
Shoof
I ordered the Alta 19mm sway bar almost a month ago, it's just sitting on the floor in the box in my office. I ordered the NM springs last week and planned to install them both at the same time. Made the most sense to me to do together! Hopefully I'll try to get them both in this weekend!
  #60
Old 07-27-2009 | 11:50 PM
dwf137's Avatar
dwf137
just a suggestion, look into getting sway bar end links to install when you get the springs, especially when going to a 22mm/25mm hollow bar. After upgrading the bar the weak link in the swaybar system is the end link. Plus, with springs you're changing the geometry of the force on the swaybar and not fully using the capabilities of the bar...
  #61
Old 07-28-2009 | 05:26 AM
Shoof's Avatar
Shoof
I don't think I would have a problem using the 19mm bar...
  #62
Old 07-28-2009 | 09:30 AM
dwf137's Avatar
dwf137
^probably not, the 19 is close to stock, but i wouldn't be surprised if it deforms on you in a few years.
  #63
Old 07-28-2009 | 11:30 AM
jeremyjcw's Avatar
jeremyjcw
Originally Posted by orangecrush
They are FAR SUPERIOR to the stock springs when comparing handling. The difference is definitely noticeable and I absolutely promise you won't regret the move.
Mark
One of the biggest handling complaints I have about my JCW with Sport Suspension is the amount of squat/dive when accelerating/hard braking. With the NM solution is this effect reduced considerably? Would a bigger rear bar help with this as well?
Thanks!
  #64
Old 07-28-2009 | 11:38 AM
Shoof's Avatar
Shoof
Thanks!
Now, I'm no professional advisor, but if you want to eliminate the squat/dive, shorter/stiffer springs will help with that somewhat, but changing the shocks should help that even more. The sway bars help when taking a turn, not when driving straight. When you have a stiffer sway bar, it reduces the side to side lean when taking a turn.
  #65
Old 07-28-2009 | 11:55 AM
jeremyjcw's Avatar
jeremyjcw
Actually when experiencing the dive/squat in a straight line, it's not really a problem. It is however, when braking hard into a corner, or coming out of one. The car can get pretty unsettled.
With a bigger rear bar I thought it might help keep the inside rear planted a little better (the force going more sideways and less up/forward). Is that not the case?
  #66
Old 07-28-2009 | 12:02 PM
Shoof's Avatar
Shoof
Than a sway bar will make a difference.
  #67
Old 07-28-2009 | 06:08 PM
alittletoored's Avatar
alittletoored
So, I guess it is my turn to chim in with a question... I've got an 08' S without the sport supension and the stock 16's. (Sorry still on a college budget) I've noticed that most everyone here either has an upgraded sway bar or is putting one on with these springs. What would these springs bring to the table without the sway bar? Also is there potential issues with camber and alignment with a stock setup + NM springs.
  #68
Old 07-28-2009 | 07:06 PM
Shoof's Avatar
Shoof
The springs are going to give you a lower stance (if you put lowering springs), and anywhere from a 15% to probably 35% more stiff ride over stock...
The primary reason that most of the Mini drivers choose to change the rear bar only as opposed to both front and rear for street use is that the Mini has the tendency to understeer (front end going out) more so than to oversteer (tail sliding out). Most agree that it's easier to control a car when it is oversteering versus understeering, and by changing the rear bar alone neutralizes the handling to reduce the tendency to understeer. The main thing the sway bar will do is reduce the lean in hard cornering and flatten the handling a bit. I had a '99 Acura TL that I put springs alone, and a few months later added sway bars (front and rear in this case), the difference was like night and day. I definitely suggest changing the rear sway bar if you're going to invest in the suspension and want overall better handling for street use and the occasional "spirited driving" urge you may have.
And remember, I'm no pro, but these are my thoughts.
  #69
Old 07-28-2009 | 08:38 PM
etalj's Avatar
etalj
I think it actually might be the other way around. When you're cornering, the displacement of the rear outside spring causes the swaybar to twist, which in turn causes the inside rear spring to displace, which in turn lifts the inside wheel off the ground. This will cause the weight to be transferred to the outside front wheel, and will reduce understeer by increasing front-end grip (if I'm not mistaken).
  #70
Old 08-03-2009 | 01:04 PM
Shoof's Avatar
Shoof
  #71
Old 08-06-2009 | 08:17 PM
ron-s mini's Avatar
ron-s mini
I have NM springs - NM sway bar - Koni FSD Strut/shocks and the ride is very good (I live a metro area also) , the handling is terrific (probably better than I drive).
The height has not been a problem, I am careful climbing steep inclines as I have splitter on the front.
  #72
Old 08-16-2009 | 04:01 PM
Shoof's Avatar
Shoof
Finally...I'm officially 1.2" closer to Earth... I didn't have time to put the RSB in, even though it probably would have been easier to do it while removing the springs, but I guess I'll do it next week. With the help of my friend's shop (using a lift and air tools) and one of his tech's, we finished the task in about an hour and a half! We didn't even take off the rear wheels while working in back, but we did take off the front wheels because we didn't have much of a choice. Anywho, here she is! Don't mind the brake dusty wheels, I need to wash it again tomorrow...
  #73
Old 08-16-2009 | 05:05 PM
ron-s mini's Avatar
ron-s mini
Looks Great!
  #74
Old 08-16-2009 | 06:28 PM
JohnJohn's Avatar
JohnJohn
very nice, now.
  #75
Old 08-16-2009 | 06:37 PM
Shoof's Avatar
Shoof
All I need is a set of JCW Challenge wheels to complete the look...
Quick Reply: Suspension NM Motorsport springs it is...
