Suspension Coilover vs springs
Old 03-14-2010 | 07:04 PM
JamesHunt's Avatar
JamesHunt
Originally Posted by iporkgoats
I'm not really gunna be happy going over $2500. I know with KW V2 i'm looking at about $2,300 for the parts
bc with swift springs and hotchkis rear controlarms will set you back 1400 to 1500
  #27
Old 03-14-2010 | 08:42 PM
etalj's Avatar
etalj
KW V2 are $1800
KW V2s + IE Adjustable camber plates + powergrid endlinks = $2400
  #28
Old 03-14-2010 | 09:01 PM
JamesHunt's Avatar
JamesHunt
Originally Posted by etalj
KW V2 are $1800
you forgot controlarms + 220 to 250
  #29
Old 03-14-2010 | 09:09 PM
iporkgoats's Avatar
iporkgoats
KW V2 are $1800
Endlinks' function is??? might as well get into control arms too
  #30
Old 03-14-2010 | 09:24 PM
JamesHunt's Avatar
JamesHunt
endlinks are adjusted according to drop so that your bars are not loaded
  #31
Old 03-14-2010 | 09:32 PM
MoxieMini's Avatar
MoxieMini
Control arms aren't really a necessity though. The camber in the rear won't get too out of control. Not enough to mess with tire wear.
  #32
Old 03-14-2010 | 11:18 PM
etalj's Avatar
etalj
Hehe didn't forget them, but I know his budget is less than 2500, so I went for endlinks rather than control arms. If he doesn't drastically lower the car, the camber should be ok.
  #33
Old 03-14-2010 | 11:24 PM
iporkgoats's Avatar
iporkgoats
What would you consider to be drastically lowered?
  #34
Old 03-15-2010 | 02:53 PM
MoxieMini's Avatar
MoxieMini
You might want to talk to Rally about this. Maybe he'll jump in. He's kind of a suspension guru. I would give you more advice, but he knows way more about this stuff and has way more experience.
  #35
Old 03-15-2010 | 03:19 PM
etalj's Avatar
etalj
If you lower about 25mm, I would say you wouldn't need control arms, but then again, that's not from personal experience, but from what I've read, because the one time I had coilovers on my R53, I already had adjustable rear control arms.
I think once you start lowering more than that, the camber starts to get hard to adjust back to stock.
  #36
Old 03-16-2010 | 10:08 PM
iporkgoats's Avatar
iporkgoats
I think i might have been talked into the Koni FSD with linear springs (NM springs maybe). Does anyone know how much lower NM springs are? And maybe i'm heading into a different section but i am getting 235/40/17 et+40 tires. Will i run into a problem with clearing the springs?
  #37
Old 03-17-2010 | 06:28 AM
JamesHunt's Avatar
JamesHunt
you will need spacers
  #38
Old 03-17-2010 | 06:44 AM
ron-s mini's Avatar
ron-s mini
I ran Koni FSD - NM springs -225/45/17 with 40 offset on my Clubman without a problem
  #39
Old 03-17-2010 | 03:30 PM
etalj's Avatar
etalj
Koni FSD are great, but I wouldn't run them with NMs (too low). FSDs are made for stock height, so I'd go with either TSW linears, or stock.
  #40
Old 03-17-2010 | 03:34 PM
JamesHunt's Avatar
JamesHunt
NM springs with a koni yellow would nice
  #41
Old 03-17-2010 | 03:38 PM
thevelourfog's Avatar
thevelourfog
I'd also vote for yellows with NM springs, that's what I'm planning on.
  #42
Old 03-17-2010 | 03:45 PM
iporkgoats's Avatar
iporkgoats
Sounds like some conflicting information. Ron any problems with the suspension (i am pretty sure you were commenting on just the tire clearance) The good news is there is no significant price difference between the two. Benefits of FSD over yellows and vice versa? This is going on a street car with possible autoX use in the future. Otherwise i'm all NYC flat pothole cornering and highway exit/entrance ramp fun.
  #43
Old 03-17-2010 | 03:57 PM
ron-s mini's Avatar
ron-s mini
This is from KONI web site
: http://www.koni-na.com/fsdeibach.cfm
KONl`s latest technology accomplishes the task that has eluded most shock makers until now - great handling + excellent ride quality:
> Excellent ride quality on all road surfaces
> Available for most newer cars - more coming
> Pair with Eibach springs for 1"-1.5" lowering
> Gold metallic finish shocks
> Dark metallic gray springs in kits
> Less expensive than electronic systems
> Lifetime Warranty
This is from NM Web site
: http://nm-eng.com/
NM RSα progressive rate spring kits provide a responsive ride, sharper handling characteristics and lowered ride height. Using exacting spring rates and precision manufacturing techniques, RSα springs provide a more pleasurable motoring experience.
Lowering Rate:
30mm (1.2") Fr • 25mm (1.0") Rr
Finish:
Powder Coated NM Blue
Why would not the NM springs work just as well as the Eibach with FSD? If you look at NM web site they sell Koni FSDs.
I ran the KONI FSDs and NM and had zero problems.
  #44
Old 03-17-2010 | 04:02 PM
JamesHunt's Avatar
JamesHunt
this is from koni tech support
DO NOT USE LOWERING SPRINGS ON THE FSD STRUT AND SHOCK BUILT FOR MINI COOPERS .
call koni if you don't want to belive me
  #45
Old 03-17-2010 | 04:10 PM
ron-s mini's Avatar
ron-s mini
Why do they list Eibachs on the website --- If you call and ask they will certainly sell you the KONI Eibach combination as listed on the link on the earlier post. Go the Web site and look call them I have. Call NM and ask.
  #46
Old 03-17-2010 | 04:12 PM
redduc's Avatar
redduc
This FSD debate is burried in another thread somewhere. A member called Koni tech support (not sales) and was told the Koni's with eibach's use a different valving and are not made for our cars (yet).
I think JamesHunt is the go to guy on this.
  #47
Old 03-17-2010 | 04:18 PM
redduc's Avatar
redduc
I ran the KONI FSDs and NM and had zero problems.[/quote]
Was the ride more harsh than stock?
  #48
Old 03-17-2010 | 04:45 PM
JamesHunt's Avatar
JamesHunt
Ron
Call koni tech support and ask(if you are too lazy to call ask Way motor works), koni will tell you the facts about FSD SHOCKS AND MINIS because koni has to warranty the shock.
Fsd will work with lowering springs on other makes.
Nm will tell you what you want to hear ,they are a marketing company.
JD
  #49
Old 03-17-2010 | 05:59 PM
etalj's Avatar
etalj
I dont like to take info from websites, cos that might be for a different car, just copy and pasted. If you can get insider info, I'd prefer to go with that.
Koni Yellows+ NM/Eibach/TSW/Swift would be very nice I'd say
  #50
Old 03-17-2010 | 07:36 PM
drfubar's Avatar
drfubar
FSDs are NOT designed to work with lowering springs on the MINI.
However for other vehicles, they are.
Quick Reply: Suspension Coilover vs springs
