Suspension Possible stripped hex bolt on strut help!
I'm surprised that the bolt would be that tight. You can use some vise grips on the shock shaft if you can get them in there, just make sure you have some padding so you don't scratch up the shaft. and don't make it too tight, definitley don't want to make the shaft out of round. Other than that, you can probably get it to stick enough to just use an impact driver on the nut to get it off, without needing the hex fitting...
on
If you want to use vise grips on your shock shaft plan on having a leaking strut in the near future. Nothing personal to the 17 year old, but that is extremely bad advice.
When I had WRX, bad advice like this was given out on the WRX forums for a DIY spring change, and many goof ***** who ended up listening to it ended up complaining of leaking shocks. Use common sence.
Find someone with an impact wrench and it should come right off.
so with an impact off the car it should come off without holding the center hex ? I have an impact but thought the center would still spin.
I know this is a bit more risky but how bout loosening the strut bolt while still bolted to car so it can not spin? too dangerous? even to just loosen?
haha thats the safe thing to do. I would never dare do it on anyone elses car... but in a pinch, i would be ok with doing it to my own. A little finesse goes a long way . I'd try the strap wrench before the vise grips though! and it seems that in most cases you can get the nut off with just an impact wrench.
on
If you never worked with struts before, just know that it can seriously hurt or kill you if you do something dumb.
Well I just got done with installing some IE fixed camber plates and had to use the strap wrench trick. In my case I already had lowering springs on so I didn't need a spring compressor. Also in my case I didn't have the right tool to allow me to turn the nut and hold the hex, so I had to use the strap wrench. To get it tightened all the way, I just put the strut back on and put the car back on the ground. In doing that I realized that pulling the top nut off with the strut still on the car would be your best route, it also relieves the need to have a spring compressor... for the front struts anyways. just be careful when you're jacking up the car, as there is a bit of "punch" to the springs. Also, the drivers side is gonna be tough to get off when using this method, I had to compress the shock (even with lowering springs on) with a jack and a piece of wood, so be careful when doing this if you do remove the nut whit the struts still on the car.
patsum
26
05-29-2021 06:29 PM
ej
11-17-2015 09:21 PM
