Suspension Coilover question, why so few H&R Street?
I've been shopping for coilovers and have looked at KW, ST, and H&R. The car is my DD and the parking garage I park in at work has hellacious speed bumps (about 3-4 per floor... it's insane) so I'm reluctant to lower the car more than 3/4" or so to ensure I don't scrape.
The only coilover I've found that will to it is the H&R Street but there seems to be very few people who run them. I found one local guy who raves about them but wanted to see if there are others.
Todd
Todd
ST/KW are popular within the Euro market. They make a great coilover with a warranty unlike others.
Here is a thread I started with commonly asked questions
https://www.northamericanmotoring.co...coilovers.html
OR, you could go with KW coilovers and the special Vorshlag camber plates they're using for the B-Spec MINI. The class specs require that the car has at least 6" of clearance below the rocker panels, so they can only drop the car 3/4".
So Vorshlag are specifically designing adapters to increase ride height accordingly so they can still use KW coilovers.
Anyway, I put in an order with Brad (actually, Matt Hair) at MINI of Charleston last week for a set of plates, knowing that the necessary spacers may not ship right away. That's not an issue for me because I am not worried about ride height restrictions just yet. Just to clarify, though, the changes to the plates for B-Spec height restrictions should just require the addition of some spacers, washers, etc., correct? No major components will change?
Basically I am hoping to use the plates without height adjustment for the time being and throw in the other pieces when necessary to meet series rules.
Thoughts?
Yep, if Brad uses the new spacers and spools I sent him then he can order the "B-Spec" plate and it will just be the right combination of parts that we already have in house, unless he's done something that I'm not aware of. We aren't doing anything custom except for the combination of parts. We're not machining or welding up anything.
All that aside, if this is for B-Spec it HAS to come from MINI of Charleston. They did all the technical and political work to get a suspension approved and get the MINI in the game!
I will try to clarify:
I ordered your camber plates from Brad at MoC so that they will be 'legal' in B-Spec.
That said, because I won't be in B-Spec right away, I was hoping to use the plates, but not use the B-Spec height adjustment until I need it.
What is the easiest way to go about that? Is the height adjustment made by just *adding* a few spacers that I could just leave out for the time being? OR is the height adjustment made by using a few *different* parts?
Basically, with what you are supplying Brad, will I be able to install that without the height adjustment and just add it later? Or would I need to get a few different parts from you guys to eliminate the height adjustment until I need it?
Hopefully this post was more clear than the last one
Thanks Jason
The height adjusting parts are just additional parts. It's a spacer that goes below the spool in the radial bearing, another spacer that goes on top of the top ring above the main plate and a custom extended top nut. You can use the B-Spec plate without these parts and be lower or with these additional parts and you should be in-spec.
eatsleepautox
10-30-2015 06:46 AM
Bea5tMa5ter
08-27-2015 01:42 PM
ki7hy
08-12-2015 07:07 PM
