Suspension rear shock spacer for koni yellows ?
Old 11-06-2012 | 06:08 AM
dboard7's Avatar
dboard7
I see these parts on Way Motor Works but do not see much info on them. They look like something that may be necessary form what I’m seeing on his site. Has anyone installed the yellows with or without these parts?
http://www.waymotorworks.com/bsh-rea...k-spacers.html
http://www.waymotorworks.com/wmw-rea...k-spacers.html
http://www.waymotorworks.com/r56-rea...ngs-or-gp.html
Old 11-06-2012 | 07:12 AM
MikewithaMini's Avatar
MikewithaMini
I had wondered the same thing. I just installed Yellows and that domed piece is integrated into the mounting of the Koni. Other after market shocks may not, thus the extra piece is required to locate the mount. You don't need em.
Old 11-06-2012 | 07:35 AM
cristo's Avatar
cristo
Alliance Member
I thought those were only necessary if you changed from the older steel rear trailing arms to the newer aluminum ones.
Old 11-07-2012 | 06:59 AM
slinger688's Avatar
slinger688
Or when you put gen 1 shocks or coils on a gen 2.
Old 11-07-2012 | 07:30 AM
dboard7's Avatar
dboard7
Cool thanks guys looks like i don't need them. Can't wait to through them on just got save up gore the camper plates and rear control arms so i can do it all at once and save on labor!
DixonL2
04-13-2021 08:05 AM
Toolman
01-20-2016 06:50 AM
blackie
08-25-2015 09:08 PM
Emnotek
08-13-2015 05:47 PM
mini yellow-haa!
08-13-2015 11:18 AM
Quick Reply: Suspension rear shock spacer for koni yellows ?
