Suspension Question about rear lower control arm install
I'm assuming you mean the inside bolt. If so, this was the tip I had posted on my MINI's timeline:
TIP: To remove the inside bolt of the lower control arm, don't bother with cutting or pushing the insulation away. Instead, get an 18mm 1 and 1/2 inch length 3/8 driver to access the bolt from the front. It's hidden within the subframe and a 1" length is too short and 2" is too long(it hits the fuel tank in front of the subframe). Just place a thin wrench to hold the bolt from the rear side, and loosen from the front.
It's kind of hard to explain the shape that the mating face of that 14-point star shaped part has. It's almost like a eccentric lobe where depending on the angle it's rotated with push or pull the wheel hub to adjust camber. When you get it apart it will make sense. When you start loosening the hex head bolt the 14-point will not move until the hex head bolt is extremely loose.
You can use an impact for whatever you want, but I would be careful and remove the bolt on the rear shock by hand. Once you remove the bolt you'll see the bolt shaft is not perfectly round, almost triangular. You'll most likely need a breaker bar or a cheater bar on the wrench you're using. It's practically an interference fit. The aluminum trailing arm is just drilled straight through at the factory and then they screw this bolt in here. It carves the threads in the hole as they wrench it down. Cost cutting at its best! Just make sure the bolt and hole in the trailing arm are clean when you torque it down. I think the value is something like 120 ft-lbs but I never was comfortable doing that to those crappy aluminum threads. Call me dangerous but I put mine back at 90 ft-lbs and marked it with a paint marker. I didn't want it to be a "Heli-coil Day".
Yeah, I stripped one getting it to the reccomended torque, on my second install (first removal for RSB, second to install shocks). Since then I have not had one loosen at 90 ft lb, and that is with lubricating the threads. The reccomended torque is dry.
The self tapping/triangular shape is to create a self locking feature. You will likely notice a bunch of metal shavings in the threads when you remove the bolt.
Mike
Mike
There are good days, and then there's days you have to heli-coil
Did this on a buddy's 08 MCS with KWv3's and we used an impact wrench. Didn't need to hold onto the shaft. Otherwise an airtool is another good option-we couldn't do it by hand. The fronts are a little tricky. We weren't sure whether to reuse certain things and frankly I couldn't even tell you how we ended up doing it(unless I saw it in person and redid it)
Use an impact gun to remove the nut on the top of the strut. After that installation is reverse of removal. I know that sounds kinda cheesy but it will make sense once you get them off. There are a few washers and shims that will sit under the cup on the front just make sure they go back on the same on both sides and you will be ok!!
And also dont forget to compress the springs, or the old fasion way of laying it on the ground and having someone put a foot on it. Once that top nut comes off the strut will shoot out the bottom of the spring about 3 ft.
