Suspension Front Sway Bar Removal??
Old 05-10-2013 | 02:44 PM
johntotah94's Avatar
johntotah94
I have upgraded my rear sway bar to a 19mm bar.
I've been hearing a lot to remove my front sway bar for better corner in or handling of some sort? Anyone heard of this or have done it?
Old 05-10-2013 | 03:00 PM
maxmini's Avatar
maxmini
How much track time do you have ? If you disconnect that front bar you better have some VERY fast hands to catch the rear end coming around. If you want to give it a try just undo one end of the bar and find a empty parking lot to experiment.
Randy
Old 05-10-2013 | 03:02 PM
johntotah94
I haven't tracked my car yet, but I will try it out like how you said. If it makes driving more fun
Old 05-10-2013 | 05:49 PM
mbwicz's Avatar
mbwicz
Bad idea to remove the front bar, car will be very twitchy and try to swap ends. Its good advice to remove the endlinks for a trial. If you want the car to rotate more, you should go to a bigger rear bar. I assume that you are full stiff on your 19mm bar?
Mike
Old 05-10-2013 | 06:33 PM
johntotah94
Yea I'm full stiffness. Probably shoulda paid extra for the 22mm. Oh wells. Not a big deal.
Old 05-11-2013 | 02:45 PM
retrogrouch's Avatar
retrogrouch
another thing to consider, despite having the improved rotation, is the loss of front end grip due to more body roll and the resulting roll induced camber loss. If faster lap times are your thing then maximizing front end grip should be a priority. Removing your front bar (unless you have massive front spring rates) is not the way to do it.
Old 05-11-2013 | 04:53 PM
countryboyshane's Avatar
countryboyshane
Doing this for track driving seems like a very very bad idea. Maybe if you had mega huge ***** for Auto-X use.
Old 05-12-2013 | 10:46 AM
johntotah94
Wow. Thanks for the info guys! Been Very helpful.
Maybe I'll do it one day for fun. haha
Old 05-12-2013 | 12:00 PM
retrogrouch
It is fun, just be ready to countersteer and give it some gas when that rear comes a' swingen!
07-16-2020 12:54 PM
silence2-38554
11-12-2015 09:39 AM
minipopkart
08-13-2015 05:22 AM
ClayTaylorNC
08-10-2015 09:19 PM
OutMotoring
08-06-2015 09:32 AM
Quick Reply: Suspension Front Sway Bar Removal??
