Suspension Torque Specs for H-Sport Comp Rear Sway Bar Bushing Brackets?
I'm going to be installing my H-Sport 25.5mm Comp Rear Sway Bar tomorrow and the instructions that came with have no torque specs at all, not even on the Hotchkis Sport Suspension website. I have all the other torque specs for everything else, sub-frame bolts, top shock mounts, lower shock mounts, end links and lug bolts. I need the specs for the torque specs on the Hotchkis bracket bushings please!
Thanks in advanced!
Systemlord.
Thanks in advanced!
Systemlord.
Thanks in advanced!
Systemlord.
Thanks in advanced!
Systemlord.
Assuming you are using stock M8 bolts to attach sway bar bracket to the rear sub-frame, torque them to 14 ft-lbs (19 Nm).
a
minipopkart
08-13-2015 05:22 AM
