Suspension R56 Stock Suspension Travel
Old 08-23-2013 | 07:12 PM
Coop-a-Loop's Avatar
Coop-a-Loop
Searched but couldn't find the info. I am just wondering how much stock suspension travel there is for a stock 2013 MCS? I assume that lowering springs reduce amount of suspension travel, but coils don't. Is this true.
Thanks ahead of time for answering.
Old 08-23-2013 | 07:32 PM
yesti's Avatar
yesti
Not a whole lot. You will find you're running on bumpstops quite a bit, it was likened to the Mazda Miata MX-5 in terms of travel.
Koni FSD shocks seem to be a great daily driver aftermarket shock, from reading these forums. The ride quality and handling are reportedly much increased. BUT you cannot lower any with the FSD shocks. I remember someone used the factory JCW 'lowering springs' which reduced height by 10mm/0.4" and is using FSD's with no problems. Any more than that and you're likely to run into problems.
To answer your question I'd guesstimate a couple (2) inches total travel, which includes time spent on the bump stops. You can trim/replace them to gain a little more but I don't know much about that.
Coilovers are adjustable for ride height but I don't know if travel changes, might also depend on the brand.
Old 08-23-2013 | 08:26 PM
Mindspin311's Avatar
Mindspin311
Ryephile has a lot of data floating out there somewhere. Search his username and you will come across it.
Long story short... barely any travel.
Old 08-23-2013 | 10:19 PM
yesti's Avatar
yesti
Found the ryephile thread. 0.2" before bumpstops on front. 1.9" compression travel. 1" before bumpstops on rear 2" compression travel. Bumpstops are progressive.
Old 08-24-2013 | 02:45 PM
Coop-a-Loop
Thanks for the info.........
07-16-2020 12:54 PM
ltjpunk7
09-06-2015 07:32 AM
sabjcw
08-14-2015 07:40 AM
Emnotek
08-13-2015 05:47 PM
Minibeagle
08-13-2015 10:00 AM
Quick Reply: Suspension R56 Stock Suspension Travel
