Suspension Slightly lowered, now rear tires rubbing
A few weeks ago I had some H&R lowering springs (1" drop in front, .75" in back) and H-sport rear camber links installed on my 06 R53. Had the alignment done and new shoes mounted. Today I noticed that I have some rubbing on the outside shoulder of my rear tires. Is this normal/to be expected, or bad alignment?
Most of the rubbing has been eliminated, just a touch when I back out of my driveway. Others have said the issue will self-correct over time, and as the rubbing is on the outer shoulder of the time, it shouldn't cause big problems. But, next time I think I'll go back to 205s instead of 215s.
I also use and like the Michelin PSS (215/40-18).
The 215/40-17 options have reduced over the last few years. Selection depends a little on how you use/drive the car.
If only used as a daily driver I would suggest:
1. Pirelli P Zero Nero GT
2. Yokohama S.Drive
If you also you the car for Auto-X and want a little stickier tire that is streetable:
1. Dunlop Direzza ZII Star Spec
2. Yokohama Advan Neova AD08 R
The do not know much about the new Falken Azenis RT615K but I suspect they will be very good.
2. Yokohama S.Drive
I also use and like the Michelin PSS (215/40-18). The 215/40-17 options have reduced over the last few years. Selection depends a little on how you use/drive the car. If only used as a daily driver I would suggest: 1. Pirelli P Zero Nero GT 2. Yokohama S.Drive If you also you the car for Auto-X and want a little stickier tire that is streetable: 1. Dunlop Direzza ZII Star Spec 2. Yokohama Advan Neova AD08 R The do not know much about the new Falken Azenis RT615K but I suspect they will be very good.
I'll look at some 215/40s when it's time for new rubber. Thanks for the suggestions👍
Mini_Vinnie
Suspension
19
08-24-2016 11:19 AM
03cooperr53
03-25-2016 12:47 PM
Suspension Thoughts on lowering springs on stock setup?
Mini_Vinnie
Suspension
17
03-11-2016 02:03 PM
