Suspension Installing B12 Pro kit need recommendations
I asked a similar question here.
https://www.northamericanmotoring.co...in-shocks.html
installing this week so I’ll update the post with my findings.
Good kit and helps if you get a bad bolt and it knocks out some future issues. Thats the simple kit. You can go higher with more parts. Most people will do the simple unless you have a a boat load of miles or you like in a salt climate like we do in ohio and everything rust like crazy/
https://www.ecstuning.com/b-assemble.../c-suspension/
Video of car before install, video to follow next week after install.
Installing this week,
- Bilstein B12 Pro Kit
- Front and rear control arm polyurethane bushings
- Front and rear sway bar polyurethane bushings
- Front and rear adjustable sway bar end links
- Rear camber links
- Rear top bump stops polyurethane
- Front strut mounts and damper washer
- Spring pads top/bottom front and rear
- Stainless steel brake lines
- Rear camber links
Scelata
05-24-2021 02:06 PM
