Suspension Creaking since lowering
Old 02-02-2005, 06:26 AM
holdenontoit's Avatar
holdenontoit
holdenontoit is offline
My fix was short lived.It's cold again and my creaking and popping noises are back with a vengeance
When the weather gets a little warmer I will put this thing up on Jack stands and crawl under it and I won't come out till I find out what the **** is going on back there.This is really tiring.
Originally Posted by holdenontoit
well halleluja!!!! I greased my rear h-sport sway bar bushings today and the creaking and popping VANISHED! thanks all for the very cool observations and suggestions.I thought I was going to go right out of my mind!Unfortunately on the way home from the dealer I noticed a new crack in windscreen #6.For those who remember, this was the FIRST of the "new" windscreens to arrive in the USA to incorporate an increase in temper,and to be fair, I've received some really dramatic rock strikes in the 10 months this was in the car,but I don't think I'll deal with this until well into the spring.Baby steps...........I also had a new belt installed at MOP and since having had a 15% pulley installed, I specified a John Cooper Works belt, slightly smaller than stock ,part # 1 11-28-0-300-802 jcw ribbed Belt. Jock
  #27
Old 02-02-2005, 06:46 AM
kenchan's Avatar
kenchan
kenchan is offline
holdinontoit- which grease are you using? I use white lithium grease on my polybushings for years and never experienced creaking.
  #28
Old 02-02-2005, 08:21 AM
holdenontoit
Re: grease type :not sure, since it was done at the dealer.I don't have as much of a creak as a *pop*.Sounds like metal on metal,doesn't happen on all bumps,but definately is road surface related.I can go over 10 bumps with nothing and then a small one and it will happen.Aghhhhhhhhh!Worse when cold, gets better with warm up.It's driving me quite batty
  #29
Old 02-02-2005, 08:25 AM
kenchan's Avatar
kenchan
kenchan is offline
Are you using aftermarket endlinks or control arms with spherical bearings?
  #30
Old 02-02-2005, 08:51 AM
holdenontoit
only suspension Mod was h sport rear sway bar, in middle position, installed by Randy Webb in Nov.
smdmini
10-07-2019 06:05 AM
massmini03
09-18-2015 05:40 PM
hydouken
09-15-2015 05:49 AM
Accessory Products
09-09-2015 10:29 AM
09-02-2015 11:15 AM
Quick Reply: Suspension Creaking since lowering
