Suspension Hard to oversteer?
#26
#28
Originally Posted by JeffS
No. Bigger rear swaybars on a FWD car increase the tendency to oversteer.
Anyway, the only way to get a FWD car to oversteer on a skid pad under power is to lift the throttle. If your foot was on the gas and you were expecting oversteer you might as well have been trying to get it to rain Mt. Dew.
And yeah, the instructor kept saying to oversteer I needed to give it throttle, and then quickly let off... But it still wasn't doing it, and throttling up, I'd go into an understeer skid before coming anywhere near fast enough to oversteer, as it was a full wet circular skidpad.
#29
A front wheel drive car will not behave the same in wet and dry conditions. The same throttle inputs that enable the Mini to track thru a turn while on the throttle will cause the Mini to lose grip and swing very wide - understeer - in the wet.
Drop-throttle-oversteer is pretty much a no-no in passenger cars these days...unless you're a Porsche whos later models are pretty stable. It is not a trait corporate attorneys like to see.
Your instructor does not know the Mini; it will drop-throttle understeer under most conditions. Staying on the throttle assertively, but gently in the begining of a turn while progressively closing the throttle as you leave the turn, is the fastest way thru turns with a stock set-up. If you were driving say a 1989 VW GTI, your instructor would be spot on.
#30
#31
The wet/dry thing is very interesting to me. The way I have the suspension set up right now my Mini will oversteer like crazy (I've made some changes:added front sway bar, played with strut settings, to fix this). When I autocross in the wet, though, it plows terribly.
I think the goal of suspension is to get a nice, four-wheel drift when cornering at speed. This setup will allow for throttle-lift oversteer and will require some skill and practice if you want to try it in the vicinity of trees, guardrails, etc.:smile:
