Suspension Show pics of your lowered MINI S!!!
Old 01-20-2006, 05:33 PM
swarley's Avatar
swarley
swarley is offline
Originally Posted by kenchan
was this a comparison before and after the swaybar install?
I was shocked with difference, it's extremely responsive, very little body roll and it's not too harsh when you hit some of the brick roads around here. Very pleased with the combination. I had my MTH Tuner file uploaded right after this install, so it's like driving a brand new car..... a very peppy brand new car
  #227
Old 01-20-2006, 07:27 PM
saakey's Avatar
saakey
saakey is offline
Originally Posted by ingsoc
I LOVE mine. No rubbing, even with 215 45 17 tires on S Lites. Maybe if you run a smaller offset you could rub outside, but probably not unless you run like 40 offset... Anyways, I couldn't be happier! And, the ride IF softer almost all of the time. Check out my thread in photography to see pictures of my ride. "El Gato Tuerto Gets M7 Springs" or something like that, it's called...
thanks...just placed my order
  #228
Old 01-21-2006, 03:28 AM
Tit's Avatar
Tit
Tit is offline
woah..look at the offset of the OZ's on the front there!
Do you rub much?
  #229
Old 01-21-2006, 05:07 AM
saakey's Avatar
saakey
saakey is offline
Holy snikies ...thats gonna leave a mark
Do you rub much?
  #230
Old 01-21-2006, 07:13 AM
kenchan's Avatar
kenchan
kenchan is offline
+27mm
  #231
Old 01-21-2006, 07:52 AM
ScuderiaMini's Avatar
ScuderiaMini
ScuderiaMini is offline
10mm spacers right
  #232
Old 01-21-2006, 10:27 AM
kenchan's Avatar
kenchan
kenchan is offline
Originally Posted by ScuderiaMini
10mm spacers right
i thought my +42 was a tight fit. +27..
  #233
Old 01-21-2006, 10:34 AM
dominicminicoopers's Avatar
dominicminicoopers
dominicminicoopers is offline
  #234
Old 01-21-2006, 10:37 AM
Strom's Avatar
Strom
Strom is offline
Actually, it only rubs a little, amazingly. I'm hoping to cure that with camber plates and perhaps reducing the front spacer to a 5mm (from 10mm).
  #235
Old 01-30-2006, 12:50 PM
pastadog's Avatar
pastadog
pastadog is offline
doesanybody know were i can find pics of a mini with espiler springs?
  #236
Old 01-30-2006, 01:33 PM
Strom's Avatar
Strom
Strom is offline
Pretty sure the Espiler springs are the same as the M7 springs.
  #237
Old 01-30-2006, 04:25 PM
///ACS330Ci's Avatar
///ACS330Ci
///ACS330Ci is offline
Here's an update pic
  #238
Old 01-30-2006, 04:30 PM
kenchan's Avatar
kenchan
kenchan is offline
very clean ride, ACS.
  #239
Old 01-30-2006, 04:43 PM
///ACS330Ci
Old 03-04-2006, 07:22 PM
Mastersonics's Avatar
Mastersonics
Mastersonics is offline
Any pictures of lowered Cabrio's?
anyone?
regards,
Charles
  #241
Old 03-04-2006, 07:27 PM
not-so-rednwhitecooper
not-so-rednwhitecooper is offline
I probably should have read the entire thread but im lazy.
I just put on my Koni springs, and only the rear appears to be lower.
How long does it typically take for a set of springs to settle?
  #242
Old 03-04-2006, 08:09 PM
Eastsidemini's Avatar
Eastsidemini
Eastsidemini is offline
lowered Mini
PSS9 with 2" drop, 18x7.5 Konig +42mm lots of trimming but no rubbing at all.
  #243
Old 03-05-2006, 03:29 PM
garretwp's Avatar
garretwp
garretwp is offline
As much as I would hate to lower the car (reasons for clearance). I might change my mind and lower it a little. what springs will work well with my car that has 17in Rota Subzeros? I would like to maybe lower it an inch and try to keep some good clearance under the car. Will I have any issues fitting the wheels that are 7.5 inches wide when the springs are installed? What is everyones suggestions?
Garrett
  #244
Old 03-05-2006, 03:42 PM
ScuderiaMini
i would strongly recommend coilovers. If you can't swing a set right now, just save money. Trust me, it is worth every penny
Garrett
  #245
Old 03-05-2006, 04:02 PM
Malcon's Avatar
Malcon
Malcon is offline
here is my...
...ok you got me...its stock
  #246
Old 03-05-2006, 04:41 PM
TLMCS05's Avatar
TLMCS05
TLMCS05 is offline
http://imageevent.com/tl4x40/mini
Before / after with Alta springs and stock run flats / after with new wheels and tires/ after pulling my other toy on a trailer, etc.
Tim
  #247
Old 03-05-2006, 04:47 PM
Jenn B's Avatar
Jenn B
Jenn B is offline
Before:
After:
M7 springs. Love them!
New wheels next month... woo hoo!
  #248
Old 03-07-2006, 04:06 PM
MX100's Avatar
MX100
MX100 is offline
My cooper S on Tein S-tech.
  #249
Old 03-07-2006, 04:25 PM
garretwp's Avatar
garretwp
garretwp is offline
How is the ride after lowering the car? I would imagine things would be much more rough on the roads. I live in NJ and in the winter when it snows, there is not much clearance even when stock. Also the roads here are not the best! To many damn potholes and stuff.
Garrett
  #250
Old 03-07-2006, 04:57 PM
///ACS330Ci
With my KW V2s the ride is better than stock.
Quick Reply: Suspension Show pics of your lowered MINI S!!!
