Suspension Show pics of your lowered MINI S!!!
Old 06-06-2007, 01:49 PM
JT MINI's Avatar
JT MINI
JT MINI is offline
Originally Posted by Konky
ride actually isn't too bad, yeah it's alittle stiff and scrapes like a b!tch, but oh it looks so damn good
You just gotta be extra cautious on shitty roads.
HOWDY!!!
You're a crazy man!!! But you're absolutely right, if you can deal with the scrapes and stiffness of suspension, you're stance does look AWESOME!!
As for CASTER - not as crazy as Konky!! And no offense mate, Konky is probably not 200lbs+ either.
  #727
Old 06-06-2007, 02:18 PM
ThumperMCS's Avatar
ThumperMCS
ThumperMCS is offline
Originally Posted by CXRK
H-Sports, Koni Yellows
Ireland Fixed camber plates
Helix Adustable control arms
I have H-Sports and Koni Yelows waiting to be installed, just wondering how you like that set up? I'm itchin' to get them installed!! I plan on getting rear control arms as well...are you satisfied with the Helix?
  #728
Old 06-06-2007, 02:58 PM
Konky's Avatar
Konky
Konky is offline
eh, 212 lbs here
but yeah, it's hard to run 15's and 16's with low profile tires without have the body of the car being pretty low. I ran into the same problem when I was running 16" Porsche phonedials, scraped like hell and wasn't satisfied with still how much wheel gap I had. For me personally, I think 17" is perfect for our cars.
  #729
Old 06-06-2007, 09:37 PM
Mini Fireman's Avatar
Mini Fireman
Mini Fireman is offline
eh, 212 lbs here
Hahahahaha gotcha beat there.
Here's how I roll (thanks to Konky for the pic)...
Here's how I used to roll...
  #730
Old 06-06-2007, 09:38 PM
Mini Fireman
Originally Posted by lhoboy
Cheaper solution: mount taller profile tires.
Please no.
  #731
Old 06-06-2007, 10:27 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rally@StanceDesign is offline
Originally Posted by Mini Fireman
Please no.
hahah scary choice there...
  #732
Old 06-07-2007, 02:22 AM
minigolf's Avatar
minigolf
minigolf is offline
Eibach springs, stock shocks. First two pics with my 17" R90 replicas, last two with 16" OEM X-lites.
Cheers Liam
  #733
Old 06-07-2007, 07:39 AM
Konky's Avatar
Konky
Konky is offline
  #734
Old 06-07-2007, 08:19 AM
JT MINI's Avatar
JT MINI
JT MINI is offline
eh, 212 lbs here
OOPPS! :impatient Sorry Konky, didn't know you are another heavy hitter in this forum as well - so to speak. J/K. I guess I'm the skinny one in the bunch, weighing in at 175lbs.
  #735
Old 06-07-2007, 08:22 AM
JT MINI's Avatar
JT MINI
JT MINI is offline
Awww man...as always, another sweet shot of your baby!!!
  #736
Old 06-07-2007, 10:12 AM
Konky's Avatar
Konky
Konky is offline
well, I'm not that fat I'm 6'1"
  #737
Old 06-07-2007, 10:17 AM
Derek86's Avatar
Derek86
Derek86 is offline
Definitely not, I am about the same wieght and you have 4 inches on me...
~ Derek
  #738
Old 06-07-2007, 11:30 AM
JT MINI's Avatar
JT MINI
JT MINI is offline
Sorry mate, I didn't mean to make it sound like I was telling you/everyone you're fat. Cause you're right, 212lbs is not fat - probably avg. weight for your height.
  #739
Old 06-07-2007, 01:43 PM
Mini Fireman
Don't worry. He's a little sensitive to fat kid jokes.
  #740
Old 06-07-2007, 01:48 PM
Rally@StanceDesign
I wanna get really fat.....that helps lower your car even more (atleast one side)
  #741
Old 06-07-2007, 02:06 PM
Mini Fireman
^^My fat a..
  #742
Old 06-07-2007, 04:30 PM
caster's Avatar
caster
caster is offline
Then the rims won't fit on my Scirocco! So, for the mean time, I'm rockin stocks.
  #743
Old 06-07-2007, 05:07 PM
Rally@StanceDesign
^^My fat a..
hahah good answer
  #744
Old 06-08-2007, 11:21 AM
astromini's Avatar
astromini
astromini is offline
wats the suspension on the the lback mini with the strats lip.. mini firmans
  #745
Old 06-08-2007, 11:33 AM
Mini Fireman
M7 coils. Click on the link in my sig pic for more details.
  #746
Old 06-08-2007, 12:37 PM
bean's Avatar
bean
bean is offline
i'm a little lower since this pic, but you get the idea....
  #747
Old 06-08-2007, 12:50 PM
Rally@StanceDesign
I bet it looks nice lowered
  #748
Old 06-08-2007, 01:53 PM
CXRK's Avatar
CXRK
CXRK is offline
Definately satisfied with the Helix control arms. They gave been holding up very well over the past year. The Koni's are "fine" but I have an issue with how the rears assemble. I finally figured it out but compared to other installs I have completed, the MINI for some reason likes to back off and loosen over time causing a "rattle" When this happens the hole in the hat (which you have to enlarge to fit the new piston through is elongated. So I reinforced both sides with a thick washer to take care of that and compressed the spring slightly so the system witll fully tighten. The KONI system as usual has a really small hex section to hold on to while you tighten the nut. Supplied is a nut and washer. Backed out. I then used a nyloc. Frigg'n thing backed out. Ok, next I tried loc-tite which I usually refrain from using since the mentioned hex is so weak. After all of this and realizing to compress the spring the tightening I could make sure the nut fully bottomed. Another mickey mouse thing is the way the metal stop is affixed. A small clip sits in a groove and this keeps the stop in place (for the hat, bushings, etc to stop against. Danm thing popped off and distorted the clip. KONI not suprisingly had plenty in stock and sent new ones to me quickly. Now the loosening thing occured with two other owners in my area so I am not unique. I'm curious to see if anyone else had this problem or has mysterious rattle or thump they ca't figure out where it's coming from.
Operation wise, they are good. The fronts had no issues going in, the adjustability is good but no clicks so you rely on base lining it then, counting how many full turns.
Honestly I'm considering some coilovers either the Bilstien PSS9, H&R non adj or maybe the M7 system. Anyone has any info or feelings feel free.
I've had the KONI"s on a little over a year.
-C
  #749
Old 06-08-2007, 03:26 PM
ThumperMCS's Avatar
ThumperMCS
-C
Thanks so much for the reply!
I purchased the Koni's used, and one of the rears was in fact missing that metal nut or clip I think that you are referring to. Koni set me a new one. I definitely think I will have someone familiar with the install procedure do the install for me judging from your post. Is there anyway to be able to adjust the stiffness on the rears after they are installed on the car or do they have to be taken out everytime? And I assume the fronts can be adjusted while on the car?
My suspension knowledge is really limited so pardon my ignorance!
  #750
Old 06-09-2007, 01:03 PM
kalbone's Avatar
kalbone
kalbone is offline
Quick Reply: Suspension Show pics of your lowered MINI S!!!
