Suspension Show pics of your lowered MINI S!!!
Old 06-15-2010, 07:20 AM
Mini Fireman's Avatar
Mini Fireman
Mini Fireman is offline
Originally Posted by Turbo_Bimmer
And the big question, would a setup like yours look funny on only a 1" drop...(set of springs)
Thanks.
Yes. If you take the low out of low and wide it just doesn't work.
  #1902
Old 06-15-2010, 08:15 AM
drink8648's Avatar
drink8648
drink8648 is offline
Here is pic with the old tires, Goodyear F1's. Now running Yokohama Avid Envigors 205/45/17. The ride is soooooo much better .
  #1903
Old 06-15-2010, 09:15 AM
Wake|MCS's Avatar
Wake|MCS
Wake|MCS is offline
Originally Posted by call it spade
going to lower it some more, just waiting for the coilovers to settle.
That looks so sinister. What size tires are you running?
And lastly, post more pics!
  #1904
Old 06-15-2010, 12:56 PM
call it spade's Avatar
call it spade
call it spade is offline
Thanks.
205/45/17. ET35 on a 7.5 for now. Lowered it some more last night. 22.75" on all corners now
  #1905
Old 06-15-2010, 01:01 PM
call it spade
They are Miro wheels btw. BBS LM knock offs.
Before I trimmed and lowered it more. haha
IMG_4058.jpg?t=1276632036
  #1906
Old 06-15-2010, 01:14 PM
DjR53's Avatar
DjR53
DjR53 is offline
nice im waiting for mine to to roll it self for more clearance Name:  IMG_0402.jpg
  #1907
Old 06-15-2010, 01:55 PM
checkmate2006's Avatar
checkmate2006
checkmate2006 is offline
Vmaxx coilvers w/IE Race camber plates and 7inch tall 8kg straight springs in front. 3inches of ground clearance on the front bumper.
  #1908
Old 06-15-2010, 03:37 PM
Dinan604's Avatar
Dinan604
Dinan604 is offline
Damn! Lookin'great!
BTW, did you use plastidip on your door handles?
  #1909
Old 06-15-2010, 03:51 PM
CSMatt's Avatar
CSMatt
CSMatt is offline
heres mine on spax springs
  #1910
Old 06-15-2010, 05:38 PM
call it spade
Originally Posted by Dinan604
Damn! Lookin'great!
nope. they're plastic molds
  #1911
Old 06-16-2010, 07:45 PM
Turbo_Bimmer's Avatar
Turbo_Bimmer
Turbo_Bimmer is offline
Anyone knows what those wheels are?
I like the deep dish.
I read that they are 17X8 et35 with 215-45-17. Would that offset be 'rubbing safe'??
Thanks.
  #1912
Old 06-16-2010, 08:28 PM
JohnnyVillan's Avatar
JohnnyVillan
JohnnyVillan is offline
^^It probably rubs a little.
Rubbing is half the fun though
  #1913
Old 06-16-2010, 08:35 PM
call it spade
agreed. 215s usually rub. Not sure on R56s though
  #1914
Old 06-17-2010, 12:24 AM
Mini Fireman
Thanks.
Brock B2 17x8.5 w/ 215/40-17 Falken 512's. With a little camber they barely rub at all.
  #1915
Old 06-17-2010, 12:27 AM
Mini Fireman
215's don't tend to rub unless you stay with a 45 series aspect ratio. 215/40 is very close to the OEM sidewall of a 205/45-17.
  #1916
Old 06-17-2010, 05:05 AM
Turbo_Bimmer
Oh, thanks for the correction,
Mini Fireman, is this your car! how much is it lowered?
Suppose I don't want to deal with the rubbing issue and play with camber (other than added camber from lowering springs), would going with a set of 205-40-17 with those wheels clear the fenders.
...I used to spend lots of time on my cars for custom fitting stuff etc, but now, 'car time' is less available, that's why I would like to find a near bolt on setup.
Thanks.
BTW the car is a R50
  #1917
Old 06-17-2010, 08:17 AM
Mini Fireman
Thanks.
Sort of. It's my wife's MINI. I just mod it and drive it occasionally. It's pretty much as low as the Cross coils can be spun down (adjusted to even up the height).
The 215/40's are already stretched a decent amount to fit. Going to a 205 probably won't help much. TBH, it doesn't rub enough to matter. If you are concerned about rubbing then I'd probably suggest you stick with a more conservative fitment closer to OEM.
If you want to research what will fit then I'd suggest starting with this thread.
Edit: Not the best pic, but you can see how they fit here...
  #1918
Old 06-17-2010, 06:27 PM
Turbo_Bimmer
Thanks for the link, a lot of info to be found in that thread. I will certainly come back for more advices.
Funny coincidence, the Mini that I'm modding is also my wife's car, and it is also PW
  #1919
Old 06-17-2010, 06:41 PM
Wake|MCS's Avatar
Wake|MCS
Wake|MCS is offline
Dialed in the rear coils today. Don't mind the 4x4 wheel gap in the front, it's going down over the weekend.
  #1920
Old 06-18-2010, 01:16 AM
Type R 564's Avatar
Type R 564
Type R 564 is offline
r those rota mc? is so if your running coilovers, did u run into any issues with the front wheels hitting the coilover its self?
  #1921
Old 06-18-2010, 08:18 AM
Wake|MCS's Avatar
Wake|MCS
Wake|MCS is offline
Yep they're Rota MCs with 3mm spacers up front. I'm running Bilstein PSS9s and clearance is really tight. While test fitting without the spacers the tires just barely cleared the locking rings. I didn't bother to check clearance with the rim and the strut for whatever reason but even with the 3mm spacer there isn't much space. For reference, I can slide my house key through that gap. My guess is there was 0-1mm of clearance with the strut (without the spacer). I'll double check for you when I adjust the front coils this weekend.
  #1922
Old 06-18-2010, 11:50 AM
smlzilla's Avatar
smlzilla
smlzilla is offline
what are the specs on the rota mc!? I think they only come in 18x8
  #1923
Old 06-18-2010, 02:20 PM
Wake|MCS's Avatar
Wake|MCS
Wake|MCS is offline
18x8 ET45. I'm running 215/40/18...
  #1924
Old 06-19-2010, 02:20 AM
Type R 564's Avatar
Type R 564
ya im running 5mm spacers, but im on springs only, gonna upgrade to coilovers soon!
  #1925
Old 06-19-2010, 07:06 PM
CRoth's Avatar
CRoth
CRoth is offline
Quick Reply: Suspension Show pics of your lowered MINI S!!!
