Those are great looking wheels (NICE MINI Too!!!!). Any trouble with tire rub? Any spacers or offset problems? Looks like enough room for larger brakes. How much did those cost? Easy to get?? Maybe the Tire Rack?
If you have stock brakes you should be fine. If you have aftermarket brakes like Brembo or Wilwood you should verify that with your wheel company before. If you are considering upgrading your brakes you should check as well. The wheel manufacturers should know which brakes will fit in their wheels.
i think im gonna paint mine! i have the same rims. the other rims i just cant afford right now, deff cant afford 18s, so i think ill do what you did. they look great.
how did you go about doing that? did a shop do it? paint, powercoat?
I have no rubbing issues anywhere. I have an effective offset of 37mm (wheels are 42 with H&R 5mm spacers). There is enough room for larger brakes, and I got them from Tire Rack. These used to be silver wheels, but had them powder coated black.
how do 18s ride? no rubbing issues? what offset should i get if i get 18s? 18x7, is that what most of you guys run?
I was slammed on 18s, and had a little rubbing. But I was also scraping the bottom on walmart speedbumps at 1mph. Lifted 1/3" from there, and no issues rubbing on Toyo Proxes4. Wee bit of rubbing when I got Pzero Neros which has about 1/3 more sidewall despite being the same overall height.
Guys, these are new rims coming out from O.Z. Racing soon. They are already out in 5x pattern, 4x100 (17" is already out) should be coming out this month (18")...these rims are SICK imo!!!
You need brakes to fill them though!
-Cody
*(And Yes, I DO know that Alex has posted about them in another thread)*
Are those stock tires? Beefy looking tread. And is it just me, or do the R56's sit REALLY high? Looking at some of these pics makes me very happy I finally decided to lower my car.
TJM
Originally Posted by Hattat
Here is my new MCS with recently added 17" OZ matt black Ultraleggera wheels.
TJM
TJM they are not the stock tires but same size with the stock tires. Yes the car is very high and I`m expecting my new H&R coilovers to lower it.
