5 lug conversion
Old 06-13-2007, 02:33 PM
meb's Avatar
meb
meb is offline
You are right! I managed to hit a pothole such that the 45 series tire wasn't even marked up, but my $600.00 forged BBS wheel was relegated to a table top. Stock wheel size, stock tire size...oh well!
  #27
Old 06-13-2007, 03:07 PM
70spop's Avatar
70spop
70spop is offline
Originally Posted by meb
Offset is the distance from the centerline to the outside of the wheel
No, no, no, no... offset is the difference between the wheel centerline and that hub-mounting surface. + if the mounting surface is closer to the outside of the wheel and - if it's closer to the inside.
http://www.1010tires.com/WheelOffsetCalculator.asp
If I'm not mistaken, backspacing is the distance from the mounting surface to the inside of the wheel.
  #28
Old 06-13-2007, 03:20 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rally@StanceDesign is offline
you're right on both accounts
Offset: Centerline (width/2) ---> Hub mounting surface
Backspacing: Back edge of wheel ---> Hub mounting surface.
I'm sure meb knows that and just mis-spoke
  #29
Old 06-14-2007, 05:57 AM
meb's Avatar
meb
meb is offline
Yup! I'm old!!! I was merely trying to establish direction - inside or outside. I should have just written it that way. Sorry!
  #30
Old 06-14-2007, 07:52 AM
70spop's Avatar
70spop
70spop is offline
No prob. I had to read through it a couple times to figure out that I thought you were mistaken. :impatient
freckles81
01-15-2017 06:33 AM
NYMADMINI
12-14-2016 02:33 PM
10-01-2015 12:13 PM
09-29-2015 12:11 PM
Quick Reply: 5 lug conversion
