Anyone used the Michelin Pilot Primacy's?
#26
We have the Michelin Pilot Exalto A/S on the BMW and the Michelin Pilot Exalto Pe2's on the Mini. Both fantastic tires and the A/S's are quiet, very good in the rain and handle darn good too and long lasting. The Pe2's are a bit stickier and will not last as long. You would not go wrong with either one.
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
#27
#28
put them on my wife's Grand Marquis,
Alex
#29
#30
Unless I hear something from this assemblage to dissuade,
Primacy MXV4 = great set of Grand Marquis
I am involved in our tire testing personally, Just letting my in car experince help you make an educated choice.
Alex
#33
For Alex @ Tirerack - so I'm a novice on tire sizes. If I want the Michelin Exalto A/S, they don't come in my OEM 195/55/R16 size. They come in 195/50/R16 (84V) or 205/55/R16 (91H) - but I don't know what the affect on handling/driveability/gas mileage, etc is by changing either width or aspect ration - can you enlighten me? This is just for normal around town/highway commute driving.
#34
205/55-16 is the better size of the two given choices and is usable with a stock suspension. Tire diameter is 24.9" vs stock 24.3".
For a lowered suspension usually look for 205/50-16 first which is slightly less than stock tire diameter. Tire diameter 24.1".
195/50-16 is much smaller than stock tire diameter and while it has enough load rating it is going to give a little odometer and speedometer error.
Tire diameter is 23.6". This would increase wheel gap using stock suspension and lower the clearance height from the ground- can lead to more scraping over uneven roads, curbs or speed bumps during daily use.
#36
i had pilot exalto a/s on a MB c230 and loved them. from those i went to the pilot sport a/s and they were better. much more firm but still had the great michelin feel.
after runflat die (which will be a while cycling with blizzaks) i will probably go with the sports if they come in the mini size
alex....question for you
Can you put a 215 45 17 on the wheels that a 205 45 17 is on now? i thought i read someone saying that was possible. i'd like more rubber on the ground if possible...or better yet what's the max width and height that is possible
#37
What size Michelin Exalto A/S for my R56 MC with 15" spoolers? 195/60-15?
Yes 195/60/15 is the best fit
Alex
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
04-01-2019 06:03 AM
