I have a set of Kumho SPT with 24,000 miles on them. They still perform
great and have plenty of tread left but they have gotten extremely noisy.
I usually run 32 psi all around. Is this normal for this particular tire or are
they going south. Any thoughts, thanks.
I do rotate them every 5 - 7 thousand miles. I think that I might just let
Santa bring me a set of Goodyear F-1's.
You are doing the right thing. Guess we can cross wear issues of the causes list. You could have a broken or shifted belt in a tire. If you rotate the tires does the sound change or move?
The tires are 18 months old. The road noise comes mainly from the rear,
but I'm going to rotate them next week so I'll see if it sounds the same or
moves to the front. Thanks.
Crashton, I see in your gallery you were at Mid-Ohio for the Rolex. I spent
some time in the paddock for the #197 and 198 cars. Got to talk to Frank
(car builder and head wrench). I learned a lot about both cars and enjoyed
his sharing of info.
the GS-D3's are pretty noisy too when they start to wear.
not as noisy as S03's, but still pretty loud if it bothers you.
if you drive around town with the window down like me it
really doesn't matter that much, but for those audiophile
types, GS-D3's are probably still too noisy.
Check the wear on the inside of the rear tires. Maybe your alignment is off (Toe settings) and that caused the tire to wear funny and start making noise. Happened to me once....
