i am running Goodyear GS D3s on 17" S-Lites and use my car as a very spirited daily driver. i am curious what tire pressure some of my peers are running on the same? thanks for your input / advice.
yes, you are on the higher end but ive seen people use over 40psi
for autox. for street i found that 38 is too high and makes the tires
hop too much, plus the ride is too firm. but that's just me.
Tire pressure is largely a function of how many people there are in your car for street use.
Different story on the track where you can adjust pressures for track or driving conditions.
For any tire used on a MINI for street driving pressures are always in the same range.
For 2 people use about 33-35 psi cold.
For 4 people use about 36 to 38 psi cold.
38 is higher but still ok, no need to go higher as you will start to wear out the middle tread of your tires.
