Torque of bolt that holds on brake disc?
After reading the threads saying how the bolt that holds the brake disc on gets stuck, I figured I'd do a bit of preventative maintenance. During my next tire rotation, I'll take that bolt out, clean it and put it back in with anti-seize. So although it probably isn't really important, I thought I'd ask what the torque should be on that bolt.
Thanks in advance.
Thanks in advance.
on
Yeah its useless for structure just an assembly thing. I changed brakes on an RSX and honda used a philips screw for that. To get it off an impact drive was a must. Not sure about the mini, but with that car the rotors are tappered and once you set the wheels on tight and they go the through a temperature cycle theyll be stuck enough and the bolt is not needed even when you take the wheels off.
07-16-2020 12:54 PM
12-05-2016 06:31 PM
minipopkart
08-13-2015 05:22 AM
