Rub Predictions Please
Okay....this is a hypothetical set up. Do you think it would cause rubbing issues?
Rim: 17x7.5 Volk LE37T, with +40mm offset
Tire: Goodyear Eagle F1 GS-D3 in 215/45/17, Tire diameter: 24.6"
Suspension: factory installed JCW. No other lowering, etc.
Brakes: JCW
Spacers: None
Brakes: JCW
Spacers: None
I thought about that, but I won't be lowering any time soon. With my current OEM set up the wheel diameter is 24.2" I thought going smaller than that with the 215/40 would look odd without lowering. THe new wheels would be 24.6" and might fill up the gap a little better.
Go for it.
Take care of those wheels. Keep them clean and away from curbs.
Do you have any recommendations on lugs nuts? I am debating between:
1. KICS R40 w/ Lock in Black Chrome (open ended)
2. Rays Extended (approx 40mm) Nuts in Black (closed ended)
black McGard SplineDrives frm Summit Racing with racing studs from PiloRacing (instead of the normal ones in case you haven't already done a stud conversion). The lugs are affordable, use a rotating set to protect your wheels and an install sleeve that fits over the lug so they work in tight recesses (though the TE37 don't need this).
Hey I was hoping you'd chime in I dont even know you, but somehow when you respond I feel better THanks for the well wishes
Now that I only use closed end nuts I have not had that problem. I lost about 12 studs that way. I had gorilla plated studs and nuts.
The finish on some of these nuts can be scraped off easily so be gentle.
Alloy nuts are light but can be over tightened and damaged (if closed ended), make sure they are long enough to house the entire tip of the stud after it sticks out from the wheel. Weights do vary some, I got two different sets and one was quite a bit lighter than the other- both were alloy and looked similar. I lighter set I got from tirerack.com.
I have seen titanium nuts but they are very expensive and someone could easily steal them even if you have locks on your wheels.
freeman727
12-10-2017 05:00 AM
wildwestrider
11
01-29-2016 06:06 PM
