215/45/17... less mpg?...
on
Since I switched from 205/45/17 (Pirelli RF) to 215/45/17 I've been getting worst mpg... I've tried Falken FK452 and Toyo PX4 now. Usually I got 300-310 miles with the 205/45/17, but now I'm getting just 275-285 with the 215/45/17...(full tank) Same driving conditions, just tires changed.
Does anybody have had this issue?... How many PSI do you usually use on your tires?
Are you driving harder [more right foot] to test the new rubber? You'll probably lose a tenth of an MPG for markedly wider tires and the road and aero drag they'll cause, but such a small tire size change shouldn't yield a noticable change. A bigger factor would be too-low tire pressure. You should be running ~36 PSI front and rear.
on
Yes, the outer diameter of the new tire is bigger, by 1.5%. That means you are actually going 1.5% farther than your odometer says. And faster than your speedo says, by 1.5%.
Also, the wider tires probably have more "road resistance" than the originals.
But that doesn't acount for all the difference you are seeing.
BTW- I get worse mpg in the summer, when the AC works so hard, my mpg drops to 29-30, for mostly hiway miles on my 2006 S.
Here's a tire size calculator:
http://www.miata.net/garage/tirecalcold.html
Stock size gives you stock performance, stock mpg.
see
https://www.northamericanmotoring.co....php?p=1634626
Tire selection is larger in 215/45-17
