Houston Roads
Houston Roads
Fellow Houstonians:
Just found out that the wheels I want in 17's are in and if I wanted to upgrade to 18's it's another $30 ea.
My question is it worth it in the long as far as the extra cost in tires and the harsher ride driving on our streets? Rubbing issues, lower profile sidewalls, ROAD CONSTRUCTION.
A friend goes thru tires very often during normal driving.
Tire size you prefer 215/40/18 or 215/35/18.
Thanks for your opinions.
Fellow Houstonians:
215/35-18 has tire diam of 24" which fits better
215/40-18 has tire diam of 24.9" which is taller than stock- will fit stock suspension but be at risk for rubbing with lowered suspension
18" wheels have a nicer big wheel look and $30 is good. But you do get more weight on each wheel so you'd make it harder to accelerated, brake fast and be nimble. I'd estimate about 2 more pounds each rim.
18" tires are probably going to be 35 series sidewalls which can be ok if you pick a tire that is more compliant and gives you a softer ride. But if you do that you do give up a little handling and traction. 35 or 40 series sidewalls are very stiff, you get good turn in response but you can feel every bump in the road.
If you roads are truely horrible then 17" wheels and tires would make the most sense- probably 205/45-17 or 215/45-17.
No matter what you get you must be very careful not to hit potholes because the shock will damage your tires, your rims and your suspension or even your shock towers (mushrooming). This means driving slow when needed- unfamiliar places, night or low visibility times, during rain or bad weather. This can take the fun out of driving.
If you really like the 18" wheels then
in 215/35-18
for a softer ride easier for daily use then consider
General Exclaim UHP (UHP Summer tire) $85 380 treadwear
These are also possible- a balance of handling and comfort-
Kumho Ecsta SPT $97 320 treadwear
BF Goodrich g-Force Sport $135 340 treadwear
or in UHP All Season tires same size
Pirelli PZero Nero M&S $156 400 treadwear
Kumho Ecsta ASX $97 420 treadwear
http://www.tirerack.com/tires/survey...ireSearch=true
I have stock susp now, however when the jcw susp comes out planning on going with that. I've heard from motoringfile (Gabe) the susp. drops the car about 1".
I think i'm going with the 17's. Now I have to figure out what tires. My dad has 215/45 on his and he says hit bottoms out alot, plus he's always having to replace them. (R53)
So 215/35-18 makes the most sense.
See if you can find other MINI owners in your area that have that sized tire to go for a ride and see what you think.
Car Care Products
12-11-2015 02:08 PM
