Anyone Use Leak Lava?
Saw this ad at Cabelas. The stuff, Leak Lava, seems to be different from Slime since you put it in your tire before any leak has occurred. If it works, without significant drawbacks, it seems like it could be a good treatment for non-runflat replacement tires if you don't carry a spare.
Anyone try this stuff (or something similar)? Work as advertised? Drawbacks? Anecdotes?
I agree with you about heat. I also wonder whether it has a limited life as a repair. If you have this stuff will you have to still do a traditional plug repair at a later date or is this it?
Can't say that I'd trust it for long term.
'prevents rim corrosion'? Sounds like it coats your rim in crap. Personally I have never experienced rim corrosion - certainly not on the inside.
I'd definitely make sure that it could be removed to install a proper patch, but then again if you don't get a flat you'd never know that you need a proper patch.
I'll stick with a plug kit and compressor.
I've used it in ATV tires YEARS ago. Worked well.
I would not suggest using it in highway tires as it could play havoc on the wheel balancing not to mention the pressure sensors as others have mentioned on here. It also adds weight which could contribute to blowouts.
It really is designed, IMO, to be used in low pressure off road tires.
I am sure someone on here has used it in highway tires though, perhaps they could shed more light and correct me if I am wrong.
10-01-2015 12:13 PM
