Most aftermarket wheels are NOT brand specific. The wheel hub is formed out larger than needed and then the dealer supplies make-specific rings that are installed between the wheel and the cars hub.
If anyone has a need for 65mm outer dia. and 56.1mm inner dia (mini size), I have two new sets (4 rings each) for sale. They are from Mackin Industries.
If their lugcentric that mean the hub-rings are necessary to CENTER the wheel on the hub. Yes, running hub-rings does make mounting the wheels easier/faster but after a couple times you learn to get pretty good at it. I'm not running hub-rings on my SSR's and I've gotten better at swapping wheels now.
Theres no better or worse really, as long as it works without vibrating...
