Best tires on the front or on the rear?
#26
I was thinking that a full size car, like a Taurus, since it has a bigger trunk overhanging extending out beyond the rear wheels would be moe apt to have the rear end swing out around a curve, thus more apt to oversteer, compared to car with no trunk overhanging the rear wheels like a MINI....but the MINI can still oversteer if the situation is right
#27
well, Michelin and Tire Rack say best tires on the rear, but I wonder if BMW and MINI have recommendations....and the article/video talk about wet weather.....what about snowy conditions?....although here in the snowy northeast, we have our fair share of snowy conditions during some winters, but the majority of winter driving is on dry or just wet pavement rather than in snow, .......and on ice, well, anything goes
#30
Oddly enough I would rather retain steering that worry about rear-end rotation.
If I lose the ability to control the front end of the car (ie chronic understeer) the fact that the rear is not stepping out is of no significance.
Unless the tires are worn to (or below) the legal limit, under normal driving conditions I would guess that it makes no odds.
In heavy rain I can easily deal with a little tail-end lightness.
If you look at how a Mini wears its tires, the fronts do a lot more work than the rears, I'd rather put new ones on the front while I have at least 1/3rd tread on the rear.
I have done this already through several sets and never had an issue.
Both of our rear-drive cars have staggered sizes (we have 15F/16R's and 17F/18Rs and a whole variety of tire sizes from 185 to 245 widths) and directional tires, so any kind of rotation is impossible, we replace tires in pairs - whichever set is worn the most.
The MR2 is on its third set of rears and the original fronts, my wife's 325i is on its second set of fronts and original fronts.
#31
#32
The ability to disperse the water and put rubber on the road is significantly impaired with worn rubber, as is the ability to swerve in the same wet conditions.
New rubber on the rear only reduces any oversteer tendancies, which the DSC defeats rather neatly.
#34
what about brake dive? your balded tire in the rear will have no traction at all. better hope you never have to brake on a curve and no electronic nanny is > physics. I'm sure someone, somewhere sometime will overcome the limits of DSC and lose it.
then there are those of us who didn't buy DSC.
#37
And the wallet thing is just perception, you'd still be buying tires at the same rate, unless you kept the rears on indefinitely, in which case they'd get pretty slippery after awhile regardless.
#38
#39
But, what about braking in wet conditions ?
We are looking at worn tread tires that still function OK wet or dry not completely worn treadless tires that need replacing.
In wet conditions or dry your worn tires should work fine but not as well as the newer tires.
If you can wear the four tires down somewhat evenly then replace all four is a good practice, then you start with good tires on all corners.
#40
Okay. Here is the definitive answer:
For those who don't pay attention when they drive, best tires on the rear.
For those who do pay attention and want the most capable vehicle, best tires on the front. It is simple. It really is. Tire companies and retailers agree: They think we are simple idiots, gross negligence in the legal world to assume anything else because the driving public proves their simplicity and ignorance day in, day out.
Paying attention, front.
Not paying attention, rear.
If you don't agree, sue me.
#41
Boy did I have fun going through wet corners. If someone had been watering too long, or washing their car, I could have a fishtailing festival. Things go quite tame when I got the second set of Pirellis.
#43
#45
When I was 16 I had a used 1957 Alfa Romeo Spider. I could only affort two tires at a time. So, reading that most of the braking was done by the front wheels, I put the two new Pirellis on the front and the bald disasters on the rear.
Perhaps most of us are thinking Best tires and good tires. I hope most of us aren't thinking best tires and bald tires. Bald tires anywhere will make you pay.
07-16-2020 12:54 PM
