What options for late 2006 MCS for Steelies?
Old 09-04-2007 | 01:03 PM
guevasd's Avatar
guevasd
Has anyone found a solution for late 2006 MCS for steelies cause of the 14mm bolt?
Is there a steelie out there for me?
I wanted to run 15" steelies with winter tires, but cant seem to find a rim that'll fit?
Old 09-04-2007 | 03:07 PM
Crashton's Avatar
Crashton
Have you called Alex at Tire Rack & asked?
Old 09-04-2007 | 03:53 PM
guevasd's Avatar
guevasd
yeah, they dont have the steels for the late 06 MCS,
cause of that 14mm bolt...
hoping someone knows of another brand out there that can work.,
thanks though..
Old 09-06-2007 | 10:38 AM
guevasd's Avatar
guevasd
So nobody with the late 2006's have steelies out there for winter use?
Old 09-06-2007 | 11:52 PM
chuck r's Avatar
chuck r
Maybe These from Summit might work. Give them a call,
Chuck
WVI-06P-5740052
:, Series 06P, 15 in.x 7 in., 4 x 100mm/ 4.5 in. Bolt Circle, 5 1/2 in. Backspace, Each
Old-time looks for front-wheel drive cars.
Get the look you're searching for with these front-wheel drive modular wheels from Wheel Vintiques. They're made from steel for durability, feature 10 holes around the circumference for style, and come with a satin black finish.
Instructions
Old 09-07-2007 | 12:35 AM
ScottRiqui's Avatar
ScottRiqui
5.5" backspacing on a 7" rim is a 38mm offset, so that looks like it's in the right ballpark.
Unfortunately, they're now listed as "not available" on the Summit site. In fact, the 06 series isn't even listed on Wheel Vintique's own website.
Old 09-07-2007 | 06:08 AM
guevasd's Avatar
guevasd
Thanks..
I guess the search continues..
I'm sure there is some steelie out there that can be found..
I'll hit up the local store this weekend and find out.. I'll call Summit too and see what they say..
I'll check out the other Wheel Vintiques options and summit I guess..
otherwise, anyone have idea for a low maintenance - low cost (<$60) rim for winter use?
polotska
08-23-2015 10:10 AM
Powershift
08-16-2015 06:14 PM
minipopkart
08-13-2015 06:22 AM
nomar116
08-11-2015 12:24 AM
08-07-2015 09:02 AM
