Show me your WHEELS!
Old 10-21-2007, 06:09 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rally@StanceDesign is offline
Originally Posted by PGT
eh, details schmetails! it's a similar look.
just wanted to make sure i wasnt losing my mind.
I really like them....what offset will you be running, Dan?
  #4677
Old 10-21-2007, 06:35 PM
PGT's Avatar
PGT
PGT is offline
me? or Mach V Dan?
My RV-F's are 17x7.5 ET42. With a 215/45 RE01R and -1.5R camber, just a touch of rubbing evident by shiny stripes on teh tires (not enough to worry about trimming)
  #4678
Old 10-21-2007, 06:40 PM
Rally@StanceDesign
me? or Mach V Dan?
I was reffering to mach V dan....but your setup sounds pretty good too I get the little shiny lines too when i load up too much in the back seat on big trips. Not too big of a deal though
  #4679
Old 10-21-2007, 06:51 PM
Mach V Dan's Avatar
Mach V Dan
Mach V Dan is offline
The Blitz wheels are +42. But I don't know if I'm going to be running them. I can't afford to keep pulling wheels off the shelf and putting them on the car!
--Dan
Mach V
FastMINI.net
  #4680
Old 10-21-2007, 07:35 PM
Sin MINI's Avatar
Sin MINI
Sin MINI is offline
Originally Posted by 1QukMINI
Daddy got new shoes. What do you think?
What size and brand, and what did they cost? I'm looking for white wheels (I know they'll be a bear to keep clean, but that's what goes with my color scheme best...)
  #4681
Old 10-21-2007, 09:04 PM
Wake|MCS's Avatar
Wake|MCS
Wake|MCS is offline
--Dan
Mach V
FastMINI.net
Haha. They do look nice though, is it worth it?
  #4682
Old 10-21-2007, 09:55 PM
Jurrell's Avatar
Jurrell
Jurrell is offline
Location: Millersville, Maryland (stationed in Beaufort, SC)
--Dan
Mach V
FastMINI.net
You can always give me the ones you don't want! Name:  highfive.gif
Size:  4.9 KBName:  tongue.gif
  #4683
Old 10-22-2007, 12:58 PM
phaedrus's Avatar
phaedrus
phaedrus is offline
I might be seeing things.....but aren't those 8 spoke?
Oh!
So they are. Never mind, then.
Anyone know where I can get a set of Rota Vectors?
  #4684
Old 10-22-2007, 01:13 PM
1QukMINI's Avatar
1QukMINI
1QukMINI is offline
They are Exel BK7s from WheelMax, 17", and are $403 for all four. I got a set of Akebono ceramic pads for the front to keep the dust at bay. The Akebonos are very much dust-free, and will work great with the white wheels. I recommend them! Good price, fast turnaround!
  #4685
Old 10-22-2007, 10:47 PM
danielo's Avatar
danielo
danielo is offline
look what the nice Fedex man gave me tonight
Nice Choice.
i'm also thinking of going the Ray direction. A set of the new Volk CE30 17 x 7.5.
As you have been thru this path before, could you please shine some light on how the Volk's centrebore matches with the mini's 56.1mm centre bore?
Old 10-24-2007, 07:03 AM
PGT's Avatar
PGT
PGT is offline
it doesn't. hubcentric rings are needed, as with pretty much all aftermarket rims including BBS.
  #4687
Old 10-24-2007, 06:35 PM
PlayPlay's Avatar
PlayPlay
PlayPlay is offline
I have Volks and I also have two sets of hubcentric rings if youre interested. The outside diameter is 65mm.
  #4688
Old 10-24-2007, 06:38 PM
halfofalmost's Avatar
halfofalmost
halfofalmost is offline
  #4689
Old 10-24-2007, 06:42 PM
PlayPlay's Avatar
PlayPlay
PlayPlay is offline
Originally Posted by phaedrus
It'd be nice to see these on a MINI. I've been looking for a 7-spoke wheel like this for a while. Actually, I've come accross them before, but they were either not listed for sale anywhere (Rota Vector) or obscenely expensive (Work Emotion XT7).
WOw I just looked up the Work EMotion XT7...you can get them in 18x7.5 in 4x100 and +42 offset....they look sweet....custom colors available too for an extra charge. Found some weight info:
Work Emotion Forged 17x7.5 15.3 lbs
Work Emotion Forged 17x8.5 16.2 lbs
Work Emotion Forged 18x7.5 16.7 lbs
Work Emotion Forged 18x8.5 17.4 lbs
  #4690
Old 10-24-2007, 07:01 PM
danielo's Avatar
danielo
danielo is offline
Ok, thanks.
BTW, what offsets did you go with?
  #4691
Old 10-24-2007, 07:02 PM
danielo's Avatar
danielo
danielo is offline
Thanks, but not quite yet. Only if my dealer can't get hold of any.
What is the best brand for hub centric rings?
And also, what offset are you using with your Volks?
  #4692
Old 10-24-2007, 07:04 PM
PGT's Avatar
PGT
PGT is offline
mine were 16x7ET42 I think. Either 40 or 42. Seems to be the best all-around from the half dozen wheels I've had on the car.
  #4693
Old 10-24-2007, 07:10 PM
Sin MINI's Avatar
Sin MINI
Sin MINI is offline
Forgot to ask...how much do they weigh? I tried a web search but weight is never listed for these wheels.
  #4694
danielo's Avatar
danielo
danielo is offline
For the RE30, i'm getting 17s and the width that comes in 17inch is 7.5
I will be reusing my 205/45/17 Toyo T1-R tires.
I'm worried the 205 width tire might look stretched over the 7.5 inch wheel.
Do you have this problem?
  #4695
Old 10-24-2007, 07:15 PM
PGT's Avatar
PGT
PGT is offline
check Toyo's specs for treadwidth. you'll be able to tell how much stretch there will be. I had 215's on a 18x7.5 and it was square (Yoko Parada Spec-2)
RE30's are nice. Where are you getting them? I can point you to someone I've dealt with before that's good.
  #4696
Old 10-25-2007, 01:07 AM
danielo's Avatar
danielo
danielo is offline
Ok.
I'm really hoping to reuse my T1-Rs. They are only 1900kms old!
I'm actually located in Malaysia. So i will be dealing with a local dealer or try to get them from Singapore, which ever is the cheapest.
Thanks very much though for the offer, appreciate it.
  #4697
Old 10-25-2007, 05:08 AM
PlayPlay's Avatar
PlayPlay
PlayPlay is offline
My Volks are 17x7.5 with +40 offset. I also have 215/45/17's and no rubbing.
I got the rings on my car from Alex @ Tire Rack. They are really nice black colored (maybe anodized?) aluminum rings I believe are meant for SSR wheels. I should have taken a photo of them before I put them on. The other two sets I have are natural aluminum and are from Upgrade Motoring, but I think their source is Mackin Industries.
  #4698
Old 10-25-2007, 05:18 AM
danielo's Avatar
danielo
danielo is offline
What brand of tires are you using?
And are your side walls perpendicular to the road?
I'm hoping my 205 will not be stretch on the 7.5inch wheel!
  #4699
Old 10-25-2007, 05:42 AM
PlayPlay's Avatar
PlayPlay
PlayPlay is offline
Goodyear Eagle F1 GS-D3's. Yes perpendicular....as far as I know. I did not consciously add any camber.
  #4700
Old 10-25-2007, 06:23 AM
eeterp's Avatar
eeterp
eeterp is offline
you'll be fine. 195 on a 7.5" wheel would stretch a bit. Besides, a little stretch never hurt anyone
Quick Reply: Show me your WHEELS!
