Show me your WHEELS!
Old 02-12-2008, 10:55 AM
HABUTGO's Avatar
HABUTGO
HABUTGO is offline
Originally Posted by MisterDangerPants
very NICE~!
Tire Size? Suspension-stock/lowerd? & with that width how much are they actually sticking out?
  #5102
Old 02-12-2008, 11:10 AM
skillet's Avatar
skillet
skillet is offline
Originally Posted by PGT
what's the light on my dash for then?
To make you think your car has a TPMS
  #5103
Old 02-12-2008, 11:11 AM
#20Works4me's Avatar
#20Works4me
#20Works4me is offline
My 02 MCS has it and it works
BTW Those wheels on HABUTGO's Mini look like crown spokes on steriods!
  #5104
Old 02-12-2008, 11:20 AM
blalor's Avatar
blalor
blalor is offline
The R50/R53 compares rotational speed of each wheel and turns on the light if one wheel goes at a different speed. That's known as the indirect method. The direct method uses sensors mounted on the wheels.
  #5105
Old 02-12-2008, 11:33 AM
PGT's Avatar
PGT
PGT is offline
check your sarcasm meter...it needs a tuneup
  #5106
Old 02-12-2008, 12:08 PM
70spop's Avatar
70spop
70spop is offline
Finally
Groovy!
  #5107
Old 02-12-2008, 12:13 PM
kenchan's Avatar
kenchan
kenchan is offline
indeed!
  #5108
Old 02-12-2008, 12:15 PM
rattmobbins's Avatar
rattmobbins
rattmobbins is offline
  #5109
Old 02-12-2008, 12:21 PM
SPECKY's Avatar
SPECKY
SPECKY is offline
Flippin love them wheels !!!!! Need details please !!!!! PRETTY please
  #5110
Old 02-12-2008, 12:58 PM
mcs22004's Avatar
mcs22004
mcs22004 is offline
The 7-spokes definitely look right on the car. If they were not as heavy as lead and did not require the 20mm adapter to get to ET35, I would have a set as well.
Have you encountered any rubbing yet? Any possibility of going to better-fitting tires for these 8.5" wide wheels when these wear out?
  #5111
Old 02-12-2008, 01:00 PM
Wolfgang80's Avatar
Wolfgang80
Wolfgang80 is offline
Habutgo,
Are those SSR MS1s on your MINI? Do you have any pictures--I looked in your gallery and didn't see any.
Where did you get them?
  #5112
Old 02-12-2008, 01:05 PM
gnatster's Avatar
gnatster
gnatster is offline
Enkei NS+M
  #5113
Old 02-12-2008, 01:54 PM
kyriian's Avatar
kyriian
kyriian is offline
Originally Posted by gnatster
Enkei NS+M
about time, that said, still not as pretty as the fikse and the bbs LMs, but better than the RCs... very very nice
  #5114
Old 02-12-2008, 02:27 PM
MisterDangerPants's Avatar
MisterDangerPants
MisterDangerPants is offline
Originally Posted by HABUTGO
very NICE~! Tire Size? Suspension-stock/lowerd? & with that width how much are they actually sticking out?
215/45/17 (Nokian WRG2). Stock suspension. I'll have to go look again, but I think the fronts are flush and the rear poke about about an inch. I think. I'll take some photos tomorrow.
Originally Posted by 70spop
Groovy!
Thanks!
RH AQ Maxilite, 17x8.5, ET35. I have no idea how much they weigh.
Originally Posted by mcs22004
The 7-spokes definitely look right on the car. If they were not as heavy as lead and did not require the 20mm adapter to get to ET35, I would have a set as well. Have you encountered any rubbing yet? Any possibility of going to better-fitting tires for these 8.5" wide wheels when these wear out?
I really like the way the S-Lites look , and that's why I got these. I like the look of the thicker 7-spoke design. No rubbing (again, stock suspension). The 215/45/17 is approved for 7" - 8" widths, so I'm not too far out of the range and would go with this size again. Though, I've only driven like 10 miles on this setup so I might change my mind after I've motored down the road a bit more.
  #5115
Old 02-13-2008, 03:38 PM
Elemental's Avatar
Elemental
Elemental is offline
I can finally post here. Drop coming soon!!!
Arospeed Kino 18" Hyperblack
  #5116
Old 02-13-2008, 07:02 PM
crazyaboutmini's Avatar
crazyaboutmini
crazyaboutmini is offline
cool rims elemental
  #5117
Old 02-14-2008, 12:40 PM
sandtoast500's Avatar
sandtoast500
sandtoast500 is offline
Elemental- Looks nice, can't wait to see it with the drop. How do you like the finish and quality of the Arospeed wheels? I could dig the Kino in 17" in gold if the finish is nice.
  #5118
Old 02-14-2008, 12:45 PM
Modshack's Avatar
Modshack
Modshack is offline
Konig Feathers with Nitto Neogen 215x45's.....Minus 8.5 lbs in unsprung weight per corner..
  #5119
Old 02-14-2008, 12:54 PM
ChrisMCS04's Avatar
ChrisMCS04
ChrisMCS04 is offline
Peace Keeper
Enkei NS+M
Absolutely B-E-A-Utiful Car...even with the bug splatter on the front, I think it gives the gnat even more character.
  #5120
Old 02-14-2008, 01:43 PM
gnatster's Avatar
gnatster
gnatster is offline
Thanks, I wish that was bug splatter. It's a new paint job for the front end that you see...From the MM.org run to Waco, On the way back I was behind another car that was being driven in a spirited manner. Loads of TX road crap on those smaller Farm to Market roads.
  #5121
Old 02-14-2008, 01:47 PM
Elemental's Avatar
Elemental
The finish is really nice. Really metalic and glossy. Make sure whoever you get them from sends you some hub rings. These wheels are 73mm bore.
  #5122
Old 02-14-2008, 01:53 PM
08R56's Avatar
08R56
08R56 is offline
Modshack, Awesome look, I think I want that set up
  #5123
Old 02-14-2008, 02:23 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rally@StanceDesign is offline
Elemental...looks like you made the right choice. Wheels look great on there. Nice and clean I look forward to seeing it dropped with a new stance
  #5124
Old 02-14-2008, 03:42 PM
MINIMM's Avatar
MINIMM
MINIMM is offline
Enkei NS+M
Looks great as usual Nathan.
One of my favorite MINI's and as a bonus, it's local.
  #5125
Old 02-14-2008, 06:50 PM
gnatster's Avatar
gnatster
gnatster is offline
But wait...there is more
A Stack of Boxes delivered by my favorite Motorhead UPS driver. He hung out while I opened the boxes.
First Layer...
Second Layer...they sure do pack these well...
Third Layer.... Ohh weeee...I see Wheel under there...
May I present....HRE C20, 18x7.5, ET43 Polished lip, brushed centers, titanium hardware
Big thanks go to PGT for pointing these out to me, Rally for answering questions I had about offsets and Tuls for overall visionary guidance.
Now to agonize over tire selection :nuts:
Quick Reply: Show me your WHEELS!
