Show me your WHEELS!
#7554
KONIG Bump in Silver
I am about to pull the triger and buy some Konig Bump 17'' silver rims. I have been looking for a picture of the silver rims with no luck so far. If anyone has Koning Bumps in silver, please post a picture.
Thanks,
Thanks,
#7558
on
Friendly reminder about the wheel finder tool I've built
Please see Browse WheelRacks to take a look at the display.
Please see Search WheelFinder to see just how detailed the search function can be.
The question comes up often about duplicating wheels already posted. Please do, the idea is that each MINI is unique and this way some performing a search can see just how the wheel may look on their particular color, or with this type of stripe...
I've written a little How-To guide: Wheel Rack - How Do I use the Wheel Rack
As a small token of thanks I'm sending everyone that enters data a sticker. Please Free* Motoring Alliance Stickers for details.
Thanks for your support in helping to build this feature into something the entire MINI Community can share.
#7559
I've had these wheels sitting in my garage for over a year. I didn't want to put them on until I needed new summer tires, and somehow, that took awhile.
They required hubcentric rings and tuner lugs, all of which I ordered separately from separate vendors, so I was sort of pleasantly surprised when everything went together and worked
They are Eagle Alloy 039s 16x7 with Kumho ASXes in 205/50/16. Really an inexpensive set-up (under $1000 for wheels, tires, rings/lugs, and install) but I love how it turned out.
#7560
OMG FINALLY!!!!!!!!!!! ive been wanting to buy these for my r53 in 18s and i couldnt find any MINI's with them, finally an actual pic of a MINI with these.
how much do they weigh?
#7561
I'm looking to get some Volk Racing Rims TE37 17's in Bronze. Does anyone have this set up so I can see how it looks or something similar? My MCS is Dark Silver by the way
#7563
I really like the white Superturismo WRC. I thought about getting them instead of the Alleggerita I have, but didn't because they are too heavy and would be too much of a PITA to keep clean.
#7564
Yep, they are a PITA to keep clean. You really have to....
1) Love your MINI and not mind spending the required time to keep them clean.
2) Have low-dust pads to keep you from going totally insane.
or....
Hate your MINI and not care what your wheels look like.
or....
#7565
on
So I'm thinking of picking up these Rota Boost wheels in 16" for my R56. I'm not sure if I need 16x6.5 or 16x7 I think either will work? you tell me.
any thoughts?
Here are the specs - If I do grab these will I need to worry about the bore size and get a "washer" (probably not called washer) to put on there?
options are:
Specs: 16x7 4x100 +40mm offset 67.1mm bore
Specs: 16x6.5 4x100 +45mm offset 56.1mm bore
thanks for the help btw
any thoughts?
options are:
#7566
both those sizes should fit
the mini has 56.1mm bore so you wouldn't need a washer (called a hubcentric ring) for the 6.5 ones
as for picking:
i would choose based on what tire size you want to run
or if you want to run in H-stock SCCA etc
as for picking:
#7567
I can't just let this go by uncommented-on. It's GORGEOUS!!!! OMG! Awesome!
I'm not just saying that because I have them on my car, either...
--Dan
Mach V
--Dan
Mach V
#7568
on
Also does a +40mm vs +45mm offset make a difference? Can you tell I'm new to aftermarket wheels? Thanks again.
#7569
both plastic and aluminum are widely used
both have pros and cons
personally i have used plastic on street/autoX/track and haven't had any issues with them melting or being hard to remove (i clean them each time i rotate my tires ~2,000 miles) <- track days are hard on the front tires
i got plastic cuz they were cheaper
#7570
on
I am looking for new wheels, i like the white mesh Tenzo M (17or 18??) but i'm afraid of the color!!
Has anyone put 18 with lowered springs?
Any suggestions?
Thanks,OJC721
Any suggestions?
Thanks,OJC721
#7572
If you're not OCD at all about your MINI, white wheels will work for you. They'll soon be black and you'll be happy.
If your'e extremely OCD about your MINI, white wheels will work for you. You'll spend 20 minutes a day cleaning them and you'll be happy.
If you fall anywhere in between, stay away from white wheels.
And if you do get them, make sure you have low-dust pads also.
#7574
But for eye-popping, show-car, stunning appearance, white wheels are IT. (at least on CR/White)
#7575
I like the white Tenzo's...the only other color that wouldn't be at least a little bit of a PIA would be black. right?
I want to know, who is a good vendor to get brands not carried by Tire Rack?
