Best tires to replace the stock runflats
#26
215/45-17 will be fine. Enjoy. Overall the GS-D3 is a good choice and very good starting point to gain more experience with tires. When you do replace them you will have a warped sense of what tires should do and how they should perform. Going to a lesser tire will be difficult.
It's like driving a MINI then getting a rental domestic sedan. It will run but you will wonder why it isn't as fun to drive.
#27
That kind of gap is similar (but less than) to stock so you may not have quite as much drop as you think.
#28
When I moved to Bridgestone Potenza S-03s long ago it was like night and day better than the Ultra High Performance Summer tire I had previously and much much better than the stock runflats. I had a relatively stock car at the time.
See what you think about-
Dry handling
Wet handling
Comfort- ride and noise
Post here your impressions.
Treadwear will require some time to determine.
Don't forget to keep tire pressure up enough for best results.
Tires are a big deal for any performance minded MINI.
07-16-2020 12:54 PM
sabjcw
08-14-2015 07:40 AM
