Best size tire for a 16 inch rim?
OK, my friend is trying to put a 205/50/16 on her cooper. I have seen 205/50/15 tires on them before but never the 16 inch version. SO is this tire an acceptable size for a mini cooper or is this too far off to fit and not look huge on the car. She doesn't want the car to look like an ATV. The previous wheels were just a set of 15 inch wheels with OEM tires.
The stock tire O.D. on my R56 MCS was 24.5" with 205/45-17. I believe the OEM tires for 16" wheels are usually about 24.4" O.D.
205/50-16 usually fall around 24.1" and 205/55-16 are usually 24.9." So, with the 50 the speedometer will read faster than you are going (even more that with the stock tires) and the 55 will tell you a lower speed. Since most speedos read fast with stock tires, the 55 might be closer to true speed.
I have 205-50-16 Kumho ASX all seasons on my MCS, and use 205-50-15 Falken Azenis for the track. The Azenis are wider for some reason but do not look out of sorts...they just make an already lowered car lower yet. The all seasons are only slightly wider than the OEM runflats that came with the car.
on
I chose 215/50 R16 but the selection is pretty limited in that size. It does match the OEM OD on the 195/55 almost exactly. The 205/50s are going to run just a tad bit under and 205/55 will be a tad over but only about 1.5% speedo error in either direction. I would agree the the new ones look a little funny with the low profile and the black trim but there are plenty of picture in show my wheels for you to make that decision. The 215s sure give you a lot of width on the 195 stock if you got room on your wheel.
DrFraserCrane
08-30-2015 01:11 PM
col127
08-21-2015 02:11 PM
