Issue with new rims
Issue with new rims
So I just picked up my R56 and had some R99s installed while I was waiting, and after I had left the dealer I noticed that when I accelerate the car pulls hard to the left. After I let up on the gas it straightens back out. Is this a mounting issue? Is it just severely misaligned? Could it be an issue with the LSD? On top of that they messed up something with swapping the TPMS because its constantly going off.
The dealer is 2 hours away and I'd much rather go to a local body shop to have it fixed.
What a way to start off with a brand new car
If you're just cruising on the interstate, you should be able to take your hands off the wheel and not have it careen across two lanes of traffic and into a ditch, right?
Good luck with the TPMS issue. My car was at the dealer for 2 1/2 weeks because of a TPMS issue. They finally figured out that the antenna on the control module, under the hood, was broken. They replaced it and everything is working fine now.
I guess we'll see, I'm going to test some different things out today to try to narrow it down, but last night even on interstate driving it was still pulling.
Its probably a combination of both to be honest, and I'm just feeling the torque steer a lot more now because its already misaligned.
Yeah, at first you said it was pulling when you accelerated, so that's why I said torque steer. If it's pulling while your driving on the interstate, then that's an alignment issue. Something could be wrong with one of the wheels also. If you bought them from the dealer and they installed everything, I would definitely take it back to them and tell them to fix it. They'll give you a loaner so you won't be without a car. Plus, I would have them fix the TPMS issue while you are there. Keep us posted.
Will do. Unfortunately the service guys don't work on the weekends very often so I'll be dealing with this till next Saturday unless I get it fixed locally. And it was my fault for not clarifying in the first post. I admit I didn't know about the torque steer, but I felt like I was fighting to keep the car straight on the entire trip home (95% interstate driving).
I'm going to put the stock rims on this weekend when I paint the brake calipers to see if that helps.
M6
on
VicSkimmr, since your having tpms issues make sure your tire pressure is balanced on both front wheels. If your a pound or two low on the left front that will cause some pull.
Not having the new tpms, does your alarm flash only or is it flash plus audible?
I suspect the alignment and tire pressure could combine to make your problem.
Did you have torque steer prior to the new R99s with the stock wheels or did you even get the opportunity to try your MINI with the stock wheels. It would give you a good baseline.
Good luck, let us know what you find out.
I havnt read through this whole thing.. but I did read everyones claiming torque steer... what I will say if your running say a 40series tire I noticed it likes to run with the road a lot. Taking the interstate to school its alittle slanted (as all of them are for drainage) and my car would pull the the slant. Only under acceleration (didnt matter how hard). so im curious, did you try going back the other way?
DrFraserCrane
08-30-2015 01:11 PM
