Tire size help- 205/45/17 to 225/45/17 - Possible?
Hi all-
Thanks for your patience. I have a 2005 MCS with the stock Goodyear Eagle RSA run-flats. I have a bubble in the sidewall of my right front tire and the rest are close to needing replacement. I have decided, after reading a lot of the posts here, that I am going to replace them with the Continental Contiprocontact SSR run-flats. Tire-rack has the 205/45/17 backordered, but has the 225/45/17 in stock. The 225's are cheaper and seem to have a higher speed rating. Can I put these on my stock 17 inch rims? What is the downside to doing this? I admittedly don't understand what the different numbers mean exactly. I am trying to balance cost, road noise and ability to do some mild winter driving in Virginia. This is very confusing!! :impatient
Thanks you so much for your help!!
Check this site out.
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Is has a really good tire size converter that includes mph differences from the base tire size....
http://www.mini2.com/forum/faq.php?faq=faq_wheels_tyres
The above thread is posted at mini2.com and, based on the table of "acceptable" tire sizes for MINIs, the 225/45R17 tire would probably be a little tall.
225/45 is about 3/4 inch taller (diameter) than your 205/45 (25" vs. 24.25, respectively). Broken down you're looking at 3/8 inch more tire at the top that can (and probably will) interfere with your suspension control arms. The only way it would possibly work is to go with a wider offset rim or purchase spacers that would go between the hub and rim. I would look for another tire and stay within specs...
on
225-45-17 Falken Azenis
You have dropped your ride height by 1.5"
You are running 225-45-17 on NEW wheels with a 42mm offset without any rubbing issues?
I have been following wheel and tire posts, while I am wearing out the crappy runflats.
I am looking at a set of Team Dynamic 17x7 with 45mm offset fitted with some Falken Azenis RT615 for track days. I am currently running stock ride height with -1.75 camber on IE adjustables. I do not intend dropping the ride height as we already have precious little suspension travel and the roads in NC are pretty crappy. I would prefer the wheels with a 42mm offset but I have not seen any with this offset.
Anybody out there running a similar setup already to what I am looking at?
Just so that I understand you correctly.
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
Kimolaoha
12-05-2020 09:32 PM
col127
08-21-2015 02:11 PM
