6UL in 15x7.5 with 34mm offset
I'm looking at these wheels on 949racing.com's website and it says it should fit the Mini.
I know with Subaru's there is an ideal offset +/- 2mm that you should use based on a given wheel width.
So is 34mm in that range for an ideal offset for a 7.5 wide wheel? Would I be adding more stress to the wheel bearings?
This would be for a stock 2005 Cooper with stock suspension driven on the streets.
Currently the stock holies (hollies) are 5.5 with a 45mm offset. According to an online calculator I would have 14mm less on the inside and it would extend an extra 36mm on the outside.
Thanks in advance for the replies.
Calculator : http://www.1010tires.com/WheelOffsetCalculator.asp
Chibi2
05-19-2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
11-11-2015 11:59 AM
vbmike
10-15-2015 04:32 AM
