Tire Size
Book mark this tire calculator
The 205/50 is 1.5% smaller than the stock tire.
205/50 is lower profile (50= 50% of 205) and wider (205mm vs 195mm).
Generally for snow you want taller and skinnier to cut through the snow/slush.
Tires have a really funny dimension coding.
The first number is the width (in millimeters), the second is sidewall height (as a percentage of the width) and the third is the wheel size (in inches!).
So, to determine the profile you multiply the first number by the second:
195 mm X 55% = 107.25 mm
205 mm X 50% = 102.5 mm
Kimolaoha
12-05-2020 09:32 PM
col127
08-21-2015 02:11 PM
