Alignment Settings for Street/Autocross
So some friends at work who are pretty experienced at autocross driving were suggesting that I get an "autocross" alignment done to my MCS.
They suggested a shop that has a new alignment machine.
When I stopped in and asked them about the alignment, they said that I should find out what settings I wanted before I have them do the work.
Since I'm a total noob and don't even know where to begin, I was wondering if any of you might have some suggestions on where I could read up on information, if you have any personal experiences you'd share.
One of the big questions I have is whether you can change the camber on the OEM setup or if different camber plates have to be installed to do that.
I tend to drive pretty aggressively on the road when other cars aren't around as well so I'd prefer a a more sporty setup than comfort concerns for daily driving.
(My Alta CAI just arrived at work today as well so I'm obsessing a bit over my car today. hehehe Can't wait to install it tonight)
Thanks guys!
Thanks guys!
You need camber plates to be able to adjust camber in the front, yes... And, to get any meaningful camber adjustment in the rear, you need adjustable control arms (lower). Otherwise, you're pretty much limited to toe adjustments...
If you get camber plates and rear control arms, I would suggest:
-2 degrees camber front, -1.5 camber rear, 0 toe front, slight toe in for the rear.
If you want a slightly more aggressive setup:
-2.5 camber front, -1.5 rear, 0 toe front, slight toe in for the rear.
Heh... I'm being lazy. I just found some stuff through Wikipedia about Toe in/out.
http://www.ozebiz.com.au/racetech/theory/align.html
on
Toe out in the front makes the MINI pretty daggone darty if you even have neutral toe in the rear. I run mine like that, with a tad bit of toe out up front, but I don't recommend it for a dual purpose car (and especially not for the track). My car takes a steady, calculated hand and requires constant attention... It works great for AX, though - most people just don't want to pay that much attention on the street.
In the rear, neutral toe can make the car a tad unstable on really fast straights (depends on your front toe and overall alignment settings). Slight toe in seems to work really well and is more stable on straights and in fast sweepers.
Anyhoo, it's not hard to make the MINI handle like crap with a bad or overly aggressive alignment. Function of the short wheelbase, I reckon? Shrug. Anyway, I've played with lots of settings to date, with and without coilovers.
on
well yeah toe out wouldn't be great on the track. I drove around everyday for more than a year with my civic with some toe out and -1.8 deg camber. I never really had trouble with instability but that was with a 103in wheelbase to the MINI's 97. Just wanted to throw out there that autox setups are usually very different from track and yours sounded like a good track one. But I would really leave it alone on the stock suspension, its going to be moving around enough that setup is a little more complex than the coilovers.
Cool, thanks guys. That's some good feedback.
I'll probably be going with H&R springs before I look into coilovers, but that's going to be much further down the road.
One of the things I'm hoping that I can help correct in an alignment is the torque steer I get to the left constantly. I was hoping that maybe adding some toe-in would even that out a little bit by pulling the car straighter under acceleration.
That page I read mentioned how toe in tends to pull the car in a straight line. Have you guys had any problems with your car pulling to the left? (dealer checked alignment twice and said that they couldn't think of any reason why the car would be doing it)
on
Hippiehobbit267
09-01-2015 06:13 PM
minipopkart
08-13-2015 05:22 AM
