looking for spacers!
I just installed M7 coilovers on my R56 cooper S and my girlfriend just got me the rims i've been wanting (ROTA Boost 17x7.5 with a 45mm offset) Only problem is that they do not clear the coilovers in the front! My mechanic says i need a 3mm spacer and it should be hubcentric to avoid any unwanted vibration.....Can any one help??
Are you still running the lug bolts or have you upgraded to Lugs and wheel nuts? The 28mm shank on the bolts will not be enough bite into the hub with spacers so you may need longer bolts if you are still running those. PM me if you are still useing bolts and I'll tell ya where to get them. There are only two MFG of the 14x1.25 bolts.
GAT
10-04-2015 07:27 PM
