What size wheel is better for 215's?
215/45-17 fits rims 7-8" wide, perfect fit for 7" rim so both rim widths will work fine.
You do get about 1/2" wider tread with the 7.5" wide rim.
You also will likely add a little more weight for the 7.5" rim.
Basically it comes down to rim selection as some will come in 17x7 while others come in only 17x7.5 or even only 17x8 sizes. Offset comes also into play as wheels with about +42 to +45mm offsets will fit better than rims with +38 offset or less depending on tire size and your suspension drop.
Performance wise you will be close and tire selection will play a bigger role than rim width.
minihune, I agree with every single thing you wrote, except that. Although the WHEEL width is going to change by 0.5", the TREAD width will barely change -- more like 0.05". The tread width is basically fixed. The only thing that's different is the sidewall shape will change slightly from the wider wheel, resulting in an almost insignificant change in the amount of tread on the ground as the sidewall changes from this |_| to this \_/.
--Dan
Mach V
--Dan
Mach V
--Dan
Mach V
--Dan
Mach V
For 205 vs 215mm wide tires and 7 vs 7.5" rims it's pretty similar.
I'm not sure if you could really see or feel much difference with either tire mounted on either rim.
Yes, in theory you may get a slight mismatch as you push the limits of fitment. Yes, you do want a good match whenever you can.
\_/ more evident with 8" wide rim and 205mm tire. Some tires do vary with how they fit on a given rim.
Functionally for the OP, both rims will work for street use and daily driving.
Rubbing is at risk with lowered suspensions and with offsets that are at the limit of fitment usually about +38 mm with 17x7.5" rims and taller than stock diameter sized tires like 215/45-17 or 225/45-17.
functionally is that they are 7.5's for my 215's. if you're going to sport
17x7, run 205/45/17's.
the differences are:
1) better sidwall stiffness for turn-ins, etc.
2) better appearance.
Kimolaoha
12-05-2020 09:32 PM
col127
08-21-2015 02:11 PM
Mini'mon
08-16-2015 04:15 PM
