Wheel spacer questions
I have an R56 MCS and was just wondering if I were to get 5mm wheel spacers if I would need longer wheel bolts, or if the stock ones are long enough.......also, since it doesn't look like there's any out specifically for the R56, wouldn't ones for the R53 work fine?.....thanks ahead of time.
if you do any kind of aggressive driving you should use longer lug bolts
on 5mm.
as far as spacers go, you dont need one specifically made for any car
as long as it has an opening for 4x100. 5mm is thin enough that your
hub should be long enough to support your wheel when you are
mounting them onto your car.
a while ago i think piloracing had some longer lug bolts. they might
still have some.
on 5mm.
still have some.
http://www.radusadirect.com/
So these would be the ones I would want to get, yes or no?
http://www.radusadirect.com/product/..._17mm_Hex.html
Along these same lines, are spacers only needed if you have a BKK or are looking for visual enhancement?
I'm looking to put 18 x 7.5 wheels on my 05 S, with an offset of +45. Right now the car is 100% stock (17 5 spokes on it). Besides lowering it , do I need to do any mods to make the wheels fit right?
Mini'mon
08-16-2015 04:15 PM
Rennfahrer555
08-13-2015 09:07 AM
ki7hy
08-12-2015 07:07 PM
