R81 tape weight balancing?
Where I get my tires done the balancer has several weight options to serve the aftermarket wheels. My R90s have no place for outside weights because of the rim design....and I would not want them there. The balancer had the option for inside weights. I see no reason for not being able to use stick-on weights provided you have the clearance between the wheel and caliper for the thickness of the weights you are using.
bctf1
01-02-2016 04:02 PM
bADbOYbECK
41
10-16-2015 12:39 PM
