Embarrassing Moment
Embarrassing Moment
I don't own a Mini, I have just wanted one for a good while. That said I got embarrassed last night by one.
I was sitting here minding my business like I do every night; I heard my wife talking to a lady see knows on the phone. "Why don't you just come by here, David can fix it for you, he has a compressor and all." I gathered it was flat tire from what I was hearing.
I'm out there looking for plugs in my truck tool box when here comes head lights behind me. Turns out the lady is driving a Mini. I lit up. I'm thinking I'll plug the tire or change the tire in a few minutes and then get a chance to drive a Mini.
I pulled the thing in my shop, jacked it up and removed lug bolts. This is where I am still lost. I couldn't pull the wheel off. I pulled and the whole car shook but the wheel never came off. I figured I'll spray it with soapy water at least and find the leak. I couldn't find a leak. I started getting nervous. I went to the manual to figure out if there was a security feature to prevent the wheel from being pulled off. I saw no evidence that such security feature existed. I went looking for the jack and tire tools to see if there was a special tool. It took me ten minutes to figure out how to open the trunk. I didn't find anything special packaged with the jack. I went to look for the spare tire, now in a panic (I'm thinking I want to at least be able to tell the lady something). I couldn't find a spare tire. There was only a battery under the rug in the back.
I'd say at least 30 minutes, maybe 45 seemed like an hour, I hadn't figured out how to take the wheel off, where the leak was or how in the hell you would ever change the tire on the side of the road. My wife walked out and ask, "how is it going?" I had to tell her "I've never been so embarressed in my life." Thankfully, while I was explaining what was going on, I saw bubbles coming from around the rim.
That was the only saving grace, I could tell the lady where the leak was and that I can't fix that.
The lady needed to get home. I never figured out how to get the wheel off or where the spare tire is. Remember it was dark, but I had light in my shop.
Please tell me what the hell am I missing? After reading a little on this forum about run flat tires, I'm now wondering if I should have plugged the tire if I had found a nail in it.
2.> If you found a battery in the back, there is no spare tire
3.> It very well might not have been any puncture, it was just leaking around the rim.
You said the leak was coming from around the rim, can't be a nail in the tread then can it? I think I'd have just aired it up again and sent her to the tire store or MINI dealer.
BTW, if it had runflats, it does not have a spare tire - that's why it has runflats........
The wheel was just stuck on the hub, a common occurence. The fix is a big hammer that you bounce off the edge of the tire on one side and then the other to work it loose, then clean and lube the hub before you put it back on.
New cars, huh? Always something different.........
You missed the part about corrosion. My best guess is the wheel was corroded onto the hub. The wheels are hub-centric & any corrosion makes them a PITA to remove. I've had to use a sledge on the inside of the wheel to break them free. Make sure the car is supported safely before trying the sledgomatic. Once the wheel is off use a bit of anti-seize or even grease on the hub center.
Where is this boot that you speak of? There was some sort of cover/hole in the bumper; I tried to put the key in there to open the trunk. Would that release the tire from underneath? I did look for a minute with my flash light under the car; I didn't see a tire.
So, when are you getting one?
And to address the smart *** comment that you did make, I did look in the manual. It showed some spring clip and a lifting tool for the spare tire. Under self inflicted pressure, I couldn't figure out where the spare tire was. I did look under the rug and the cover to find a battery.
I really don't blame you for the smart *** comment. If I was in the know, I feel like I would heap it on too.
Wasn't meant to be smart ***, was meant to be helpful, much as my 1st post was. It is surprising at the amount of people who never even look at the owners manual. Also never really understood why so many Owner's manuals show up for sale on Ebay, and how many cars on a used car lot are without them, considering how important of a role they provide
(PS, Been dealing with vehicles for many years, foreign, domestic, classic and collector, I've never been to proud to read the manual)
Don't feel bad - it's not readily apparent that the MINI Cooper S, aka MCS has runflats and no spare. I'll bet the battery in the boot/trunk really threw you. By far the most baffling is the stuck wheel. Common for the MINI, but not for the general populace.
The proper advice has already been stated here - a good couple of kicks/BFH and a 2x4/dead blow hammer will get the wheel off. I wouldn't have known had I not been reading this site for 2 years before I got my MINI. Definitely lightly grease the hub once it's off.
So have her come back, and show her that not only are you manly, but you have retained the ability to learn as well!
Yes it was a S version.
And another thing, I haven't had a chance to drive a Mini yet. I did drive it to my shop (75ft). I have to do a u-turn to get in my shop door. Too sharp to make it without backing up (even in the Mini). I went to put it in reverse and it kept trying to go forward. I, after stalling three times and inching ever closer to the post of my shop, had to turn on the dome light and find out reverse is not in the "normal" position.
I still want to drive one bad to determine if I want to purchase one as bad as I think.
I'm pretty confident that if you test drive a MINI it will only amplify your desire for one
the owners manual..
well..
i spent a good hour.. one day.. trying to get under the hood of my car.. i was on the ground looking up under the dash for the hood release.. grabbed the good old owners manual.. and read.. thinking what in sam heck! yeah then i realized.. the manual.. was actually telling me to open the hood by the release on the drivers side..
that being side.. drivers side of a British car.. lo and behold there it was.. right where it should be.. on the passenger side lmmfao
well..
You're making progress!! You called it a "bonnet" and not "the hood"!
You'll be prepared to motor amongst us very soon. Get to a dealer quick. This desire does not diminish...it only increases until a) you get one, b) your family has you committed, or c) we find you balled up in a corner, rocking yourself, sucking your thumb, and crying!
Oh! - and be warned....many 2 and 3 MINI families are out there....simply because the love and passion for these little cars is irresistable!
