Konig feathers?
Konigs are generally medium quality. They're better than some of the cheap knock-off brands that you find on ebay....but they're not up to par with some of the good quality wheel companies. They're a good wheel for the price
The Konig feathers are a nice looking wheel and seem to be pretty popular recently
If you plan on buying Feathers, check out Good-win-racing. He has very good wheel prices. 17s are $129 and 16s are $100 (ea)
http://www.good-win-racing.com/mazda/miata/index.html
on
high quality wheels ,what are they?
I haven't figured out the difference in so called high quality and low quality ,knock off wheels. Do the cheap wheels wobble or they not round? Fit badly?Turn into goo after a while?Forged wheels are stronger so what does that mean? A few pounds lighter? Will they deflect less around a curve and therefore handle better? Will they not bend in a pothole? Will the finish look better?
The finish is the part that will stand out the most. Visually the finishes are much more appealing on higher quality wheels. The finish will also last much longer. PGT pointed out that when he went to sand the paint off his enkei wheels (comparable to konigs), the paint was very thin and came off with ease. This is the same thing I've experience on the cheaper wheels that I used to run...the clearcoat would flake or the paint would chip. I had a set of Fliks (medium quality like konigs) and because rocks had chipped the weak clearcoat, water and dirt was getting under the clearcoat and causing all sorts of trouble.
In general, they will be much less likely to bend in a pothole as well. I've seen pictures of Rota's that have literally shattered upon hitting a pothole.
No, lower quality wheels won't turn into goo after a while, and they will probably handle fine out on the road....but I like to compare it to choosing a car. Buying cheap wheels is like buying a Kia....it's a nice low price, they take a lot of styling cues from higher end cars, and it still gets you from Point A to Point B.......... but the interior looks a bit cheap, the performance and driving experience is lack luster, and it may not fare as well in a crash.
like Traklites, the NT03+M I have from Enkei are actually better than their cheap stuff....MAT construction. Enkei OEM's for Subaru - the wheels on '06+ WRX's are MAT as are the one's on the '07 STI Limited (MAT Enkei wheels instead of the normal forged BBS). Enkei can do OEM finishes...they just don't do it on any wheel that I've seen aftermarket (quite a few so far from them).
on
Feathers installed today....Awesome. Dropped 8.5 lbs per corner in unsprung weight. Enough that it is immediately noticeable in acceleration and suspension action. Wrapped them in Nitto NeoGens 215x45 17's. They feel good so far!
Don't forget your hubrings...73 x 56mm
on
Thanks! Don't worry...Only had the car a week! I'm a bit of a Mod freak...
Over 6000 Mod pics from my other cars here! http://public.fotki.com/ttschwing/
I gotta work my way into it for a few days...
on
Those wheels look great on the PW. I was considering the same ones for my CR/white roof. I'm just not sure about black wheel and the white top. I have white ones now and they look good but are a bit happy looking. I was thinking about playing down the cute look more in favor of a more aggressive touch . What you think?
Hey Modshack, so you have been running this wheel for 2 months now. What is the current state? Any chipping or signs of peeling finish? I am considering this wheel or the Motegi FF7s in black with polished lip, but I really like the satin finish of this wheel. Any feedback is gold. Thanks!
on
Still perfect and looking just like the day I put them on there! No issues at all...Go for it!
