Hawk HPS or Ceramic?
#26
#27
#28
#29
stainless lines are noy just bling they are stroger then stock and can take more stress. i had a friend that race years ago that had a wheel fire becouse his stock brake line brock and put hot brake fluid on to a hotter rotor. fyi that was back in the day you could not upgrade them for scca stuff. i just order my new lines this week for my 07mcs
#30
#31
#32
#33
The point here was to show how the top two are constructed, the fitting (end piece) has a very small diameter shank fitted into the hose and is a weak spot, prone to breaking, also they are prone to kinking very easily. The hose on the bottom has an end fitting which incorporates the inner shank (which inserts in the hose) as one piece with the outer crimp fitting for added strength.
Please see this post for more details. https://www.northamericanmotoring.co...d.php?t=133690
--Dan
--Dan
#34
#35
Dan, not trying to knock your product, they look to be quality hoses, but the two failed hoses look to have been improperly fitted. A properly fit hose will never be trying to kink at the fitting like that. Maybe they are too short and do not allow for a proper bend radus?
Jason
Jason
I did not fit those hoses myself, but they were supposed to be correct for their applications. I know that aftermarket brake hose failures are rare, but I have found a superior product for not much more money, and I am enomoured with the quality and feel it is a better alternative to what has been offered so far. The kinked one on top was improperly fitted and I believe to be a common mistake. The one in the center broke as I turned the wheel to full lock to remove the opposite side caliper for a pad replacement. I would like to point out the fitting construction, because this one broke very easily, the fitting in the bottom pic does not have this weak spot.
-Dan
#36
#37
Sorry to hijack this thread, it was really not my intention.
I like the hawk ceramics enough to stock them, they have a good initial bite, resist fade well, but will overheat with extreme use (but so will the stock pad and the HPS) The HPS does not have as good a first bite as the stock pads, but with a little heat they work very well.
I would be happy to finish the brake hose discussion here https://www.northamericanmotoring.co...d.php?t=133690 And I have also posted a side by side comparison of a few brand new hoses, to be fair.
#39
#40
on
I just did a brake upgrade and replaced the stock pads w/ the HPS. I also replaced the rotors (to Zimmerman drilled), brake lines (to ss) and fluid (to BLUE). It took two attempts to set the pads but now that they are set, I find
cold they appear about the same as stock.
hot they bite better than stock.
