stock MINI lugs/bolts on Konig Wheels?
I have Konig Britelites and yes I had to have the rim drilled. My dealer sent them back to Konig to get it done. This was done to accomodate the larger lug bolts (14mm) that come on the R56. The bolts from the previous generation car (12mm) would have worked fine.
No reason why these should just not bolt on with factory lugs unless you need spacers for clearance. If the lugs are covered then studs most likely would not fit, as they might stick out to far.(?)
definitely get hubcentric rings if they are not already hubcentric.
If the rims are hubcentric then you could just have done the drilling yourself. It's the hubcentric hub and the 'taper' on the lugs that align everything.
im going to get the rings for sure, theyre like 15 for all 4, dont know if theyre plastic or not. im ordering from Discount Tire Direct.
the "installation kit" i referred to is what discount tire direct calls it.
it basically is the studs or different lugs that you "need" but i guess i dont need them on this wheel: http://www.discounttiredirect.com/di...100&vid=007438
i will
im going to order today.
should i get the certificates for free replacments for the Nitto NeoGens, $16.50 a tire, $66 total extra on the order.
from the site:
Ever had a blowout on the freeway? How about a run-in with a pothole? You've no doubt seen debris in the road such as broken glass and nails. Our Certificates for Free Replacement eliminate the financial burden of replacing these damaged tires.
Your spare tire is a temporary solution. Unfortunately, more often than not, the tire cannot be repaired and must be replaced. Now imagine this happening while there is still plenty of life left in the tire. Having to pay for a tire twice would frustrate anyone.
How am I covered?
In the event one or more of your tires fail due to defect, or incurs damage that cannot be repaired, Discount Tire Direct will replace it absolutely FREE, (this includes freight to you). Regardless of the number of miles you put on the tires, you will be covered for the life of the original tread down to 3/32" remaining, or 3 years from the date of purchase. We have been offering this warranty for over 30 years. This Certificate for Free Replacement is unbeatable in the tire industry!
How do I redeem the Certificate for Free Replacement?
There are two convenient ways you can redeem this certificate:
1) Call any sales agent at Discount Tire Direct, tell them you had a tire problem and are covered under our Certificate for Free Replacement. A replacement* tire will be sent to you free of charge. At that time, you do have the option to purchase the Certificate for Free Replacement for the replacement tire.
Note: Discount Tire Direct reserves the right to have damaged tires returned for inspection.** This will be at the owner's expense.
2) You can go to any Discount Tire Company/America's Tire Company retail store. Their friendly staff will be happy to help you to get the replacement* tire you need.
Can I purchase the Certificate for Free Replacement after I buy tires?
If you have not purchased the Certificate for Free Replacement for your new tires, you have 30 days from the date of purchase to do so. You can do this by giving our courteous staff a call at 888-852-7476. Tell them you would like to buy the Certificate for Free Replacement for your tires. Remember, the sooner you call, the sooner you will be covered!
What do the Certificates for Free Replacement not cover?
Abnormal tire wear. Reasons for abnormal wear include a vehicle being out of alignment, suspension problems or improper tire inflation.
Damage caused by collision, vandalism, or willful abuse.
"Cupping" due to lack of rotation. Tires should be rotated every 5,000 to 7,000 miles.
Tire(s) worn past the wear bar.
Labor in regards to mounting, balancing or bolting on of new tire(s).
In what states are the retail outlets located?
Our parent company has outlets in Arizona, California, Colorado, Florida, Georgia, Illinois, Indiana, Michigan, Minnesota, North Carolina, New Mexico, Nevada, Ohio, Oregon, South Carolina, Texas, Utah, and Washington.
*In the event the registered tire is discontinued or not available, a tire of similar value will be substituted.
**Please read "What is not covered" regarding inspection. Tires returned for inspection must pass those guidelines for credit to be issued.
from the site:
How am I covered?
07-16-2020 12:54 PM
12-23-2015 10:36 AM
jrezzo
08-09-2015 10:32 PM
