Tire choice
Tire choice
Quick question: Decided to stick with run flats for my second set. Hate the Dunlop sport things I got with the car so need to change. Have a choice between the Goodyear Eagle thingies or the Continental contipro thingummy bobs. Which ones to go for. Criteria: Road noise, handling (mostly dry) but bumpy roads, length of tread life...so which to go for? Any help would be appreciated.
Just FYI. I had one of my Dunlop runflats repaired yesterday because of a nail in the tread. Done by Discount Tires, easy fix. Anyway they showed me the price of the three manufacturer's runflats and added that Goodyear will not permit their runflats to be repaired, must be replaced. If that's universal or not I don't know. Just food for thought.
Off topic; I was impressed by the sensitivity of the system. The warning light came on with 35psi in the three good tires and 27psi in the bad one.
Which model Dunlop run flat tire did you have? I actually didn't mind the stock Dunlop SP5000s that came with the car. Other than the rough ride, I thought they were a good all around tire.
I'd suggest you give tire rack a call and get their input also.
I personally hate the Goodyear RS-A tire also. Absolutely terrible grip in any condition.
205/45-17
195/55-16
How many miles did your first set of tires last? Did you rotate tires every 5000-6000 miles?
The Kumho ASX (or is it SPT?) is available as a runflat for cheap, and has good reviews. www.tirerack.com is your friend...
The Kunho ASX (or is it SPT?) is available as a runflat for cheap, and has good reviews. www.tirerack.com is your friend...
Kumho Ecsta SPT XRP Runflats Ultra High Performance Summer tires
340 treadwear Both in stock
195/55-16 $128 each 25 lbs (reasonably priced)
205/45-17 $139 each 28 lbs
For Grand Touring All Season Runflat tires in 205/45-17 (in stock)
Continental ContiProContact SSR $182 each
400 treadwear, works in light snow.
Also comes in-
195/55-16 $122 each (back ordered at tirerack.com)
205/55-16 $120 each (back ordered at tirerack.com)
My '07 "S" came with Dunlop 17" Sport 01's and they were the worst tire I ever had. You felt every bump... which really grows old after a year or so! After apparently hitting a pothole my front left Dunlop had a small bubble on it... I decided to get rid of them and put on a set of Continental Pro Contact run flats. The seem to get the highest overall ratings for an "all season" type tire. My car drives better then ever, the bumps are smoothed out, the car corners great and they are really quiet. I will never go back to Dunlop. Just my opion...
Jonny,
I have a set of barely used ContiPro Contact SSR all season run flats that I would like to sell. They are the original equipment 195/55 R16 that came with the car. I have 1500 gentle break-in period miles on them. Nothing wrong with them, I just don't care for run flats.
Tire Rack's web site lists them for $122 each. I'll sell mine for $90 plus shipping (continental US only). If you live in the Seattle area you could pick them up.
If you're interested, please send a PM or look for the add that I'll post on the marketplace forum later today.
